Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
How to replace the lamp - Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
  • 1,476 Answers
Chinbachnq,
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which should get you through the process and lists the best places to get lamps.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Aug 20, 2010
Said replace lamp, now doesn't turn on
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Apr 08, 2012 | Televison & Video
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
I am trying to replace aleft rear turn signal bulb on a 2005 lacrosse. I removed two wing nuts but cannot remove assmbly. Is there another wing nut holding it in. I cannot find it?
3 wing nuts. here is the info needed.
gmlogoflat.gif Service Information
bhome.gifbpublication.gifbnumsrchbutton.gifbnews.gifymkbutton.giffeedback.gifbhelp.gif
2005 Buick LaCrosse ' Allure, LaCrosse VIN W Service Manual ' Body ' Lighting Systems ' Repair Instructions ' Document ID: 1537542 Tail Lamp, Turn Signal Lamp, High Mount Stop Lamp, License Lamp, Backup Lamp Replacement - Rear
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Turn Signal/Stop Lamp Assembly Replacement - Rear 1
Nut, Turn Signal/Tail Lamp (Qty: 3)
Tip
Pull back rear compartment carpet to gain access to lamp.
Tighten
2 N·m (18 lb in)
Lamp, Turn Signal/Tail Lamp
Tip
Twist the bulb socket and pull inward to replace the bulb.
License Lamp Replacement 3
Screws, License Lamp (Qty: 2)
Tighten
2 N·m (18 lb in)
Lamp, License Lamp
Tip
Jul 29, 2011 | Buick LaCrosse Cars & Trucks
HOW DO I REPLACE THE LAMP
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
May 18, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Where do i find the ballast unit, both inside my projector and for sale?
In the optoma hd-81 there is a lamp unit housing.It goes faulty the lamp unit housing .There is no ballast in the hd-81 projector.There is lens ,the lamp unit housing and the circuit board.In most of the cases the lamp unit housing goes faulty.In that case the lamp housing needs to be replaced.It can be replaced and replacement lamp is also available. -------------------- Buying original lamp is always advisable.But there is compatible lamp also available.The original lamp housing is costly and compatible housing is bit cheaper.In some rare cases the compatible lamp does not work.But the compatible lamps also are good. To buy original lamp.Click this link directly:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/Optoma+Technology+Inc/Optoma/BLFS300B/New.aspx ------------ this is link for compatible cheaper lamp.Click this link:-- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx --------------- The procedure to replace the lamp:--- to get this procedure.Please click on the link below:--- http://www.partstore.com/Part/Optoma+Technology+Inc/Optoma/HD81/DNGO/DNGO/BLFS300BRL/New.aspx ------------ this link is for the user manual of optoma hd-81 and the procedure to replace lamp is mentioned on page number 59.Please read the instructions before replacing lamp.----------- This will help.Thanks.Helpmech.
Feb 03, 2011 | Optoma HD81 DLP Projector
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
The lamp went out on our 4 year old 42" samsung, model #HL-R4266W where do I get a new bulb and how do I change it
Check the following before replacing the lamp:
  1. The replacement lamp must be of the same code number and type with the old one.(Samsung BP96-01472A Lamp)
  2. The lamp type is indicated on the right side of the TV. It is also indicated on the lamp case.
  3. You can search online where to buy replacement lamp.
Caution:
  1. Replace the lamp with the correct lamp type to avoid damage to the TV.
  2. Turn off the TV and wait for 30 minutes before replacing the lamp to allow it to cool
  3. Do not touch the glass part of the lamp with your bare hands nor insert any foreign object inside the cover as it may cause poor screen quality, electric shock or fire.
  4. Do not place the old lamp near flammable objects or within the reach of children.
Tools needed:
  1. Phillips screwdriver and a pair of gloves.
Procedure:
  4. Separate the Lamp from the engine by holding the handle and pulling it out. 3cd3c78.jpgc21b6a2.jpg
  5. Reinstall the Lamp by following these steps in reverse order.
  6. Align the lamp cover with the groove and secure the screws. The TV will not turn on if the lamp cover is not correctly closed.
Nov 27, 2009 | Computers & Internet
I have a OK Lighting touch lamp and three of the glass planels are broken do you kow whenere I can get replacements
Hello there:
here is several links that will definatly help you in your quest to find touch lamp glass ok? look below mainly # 3
best regards michael
  1. Lamp Shades - Glass Lampshades - Silk Replacement Lamp Shades - 2000 item catalog of glass lampshades, silk replacement. ... Finishing Touch - Finials. Tulip - Lilly - Large -Small. Oil Lamps & Fonts ...www.specialtylampshades.com
  2. Speciality Lamp Shades Add a finishing touch to your shades. Reverse Painted & Dome Glass Shades ... Replacement Glass Lamp Shades- Reproduction & Custom ...www.specialtylampshades.com/lampshades.html - Cached
  3. Touch & Glow Replacement Kit | LampsPlus.com 3-way touch lamp. Saves energy. Extend bulb life. ... Glass Shades. Light Bulbs. Night Lights. Under Cabinet. View All Categories. Bathroom Lighting ...lampsplus.com/.../Touch-and-Glow-Replacement-Kit__35098.html - 110k - Cached
  4. Elegant Touch: Brown's Lampshades ... a special accent for your special lamp and replacement lamp shades. ... Glass Small Tear Drop Lamp Finial. c3-finial $12.95. Crystal Gothic Cross Lamp Finial ...brownslampshades.com/store/ctgy/elegant-touch.html - Cached
  5. Nec Display Solutions 50016683 Replacement Lamp - Yahoo! Shopping Yahoo! Shopping has Nec Display Solutions 50016683 Replacement Lamp. Quick Links: Specifications - Description - Compare Prices shopping.yahoo.com/p:Nec Display Solutions 50016683 Replacement Lamp... - 126k
  6. Replacement Shade for 2198 Floor Lamp - Shop.com Shop for Replacement Shade for 2198 Floor Lamp and Floor Lamps at Shop.com. the 2198TA lamp was designed by fontana arte in 1954. a very dignified modern touch to an...shop.com/replacement_shade_for_2198_floor_lamp-59830151-7...
lamp
Sep 24, 2009 | Electrical Supplies
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
