Question about Sony Playstation 3 (PS3) Console
My ps3 turns on but then turns off straight away
  • 277 Answers
Again, people assume because it is blinking red that it is the "YLOD", better known as a hardware failure.
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Posted on Aug 20, 2010
Every time i try to turn my ps3 slim on it turns off straight away
okay, ummm could be YLOD aka yellow light of death! rarely happens to slims but it can (obviously) anyways if you turn it on then it shuts off see if the led's on console flash at you if so then thats what it is
Sep 15, 2013 | Video Game Consoles & Games
My ps3 starts as nprmal but after 2 or 3 minutes the red light flashes and it shuts down but will restart straight away but shuys down again
Sounds like an overheating problem. Keep it away from dust and try to clean the fan out. Happened to me a couple of times till I took care of the fan
Sep 07, 2011 | Sony Playstation 3 (PS3) Console
I push power and it shuts off right away... then i unplug power and the red light comes on ....still i press it and it goes off again
Hi russell,
The PS3 red light is a huge problem and it is caused by the GPU and the CPU overheating, all you need to do is stop the heat build up.
You have 2 ways of doing this:
You can send it in however bear in mind that for the fix you will have to wait for 4 weeks and also pay out $150 as well.
Or you can use a good PS3 Repair guide to fix the problem.
Make sure you check out these reviews of the top PS3 Repair guides first!
Cheers!
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
I turn on my ps3 it turns off straight away and the red light flashes and its not overheated....????
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
If that doesn't work then that means either the power supply is bad or the mainboard is bad.
May 31, 2010 | Sony Playstation 3 (PS3) Console
The system is turning it`s self off, the red power
it must be Bricked then,try to unbrick it using the pandora battery
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns off straight away and flashes red
it sounds like you have a short in the system. take it to a repair plase. don't try to service it your self it will disable it self if you take off the cover.
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
Weird noise
sounds to me like your fan is on the way out and the bearings are seizing up.
if its in warrently please give sony a ring,
if not browse ebay for a new fan and heat sink and use this link to help you fit it: http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
hope this helps :)
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
