Question about Royal Office Equipment & Supplies
I HAD A PAPER JAM, HAVE REMOVED THE OBSTACLE BUT NOW IT WON'T SHRED
  • 732 Answers
Monaswan, If the motor refuses to run, unplug from wall outlet. Then let it "cool down" outside for about 1 hour. Then try it again. There is a "temperature sensor" inside unit that "opens-up" and will not let it run until the ambient temperature falls to a safe operating area. Reply after 1 hour and let me know if that was solution!!! 12fixlouie
Posted on Aug 20, 2010
Printer will not print. says there is a paper jam but printer is completely empty
Check again. Sometimes you thing you got all the paper out but didn't. Did the paper rip when you removed it? If it did, check for small shred stuck in the jam sensor(s)
Aug 07, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Paper jam
Need to make sure every last little shred of paper is removed check the rollers carefully
Jan 08, 2013 | Samsung ML 1610 Laser Printer
False paper jam
I had this problem with an HP Laserjet printer. An old, dry piece of paper got mangled as it fed through. I finally used a bright LED flashlight and examined the entire paper path. Found a tiny shred of paper lodged deep inside. Removing that tiny shred with tweezers solved the problem.
Sep 02, 2012 | HEWLETT-PACKARD Hewlett Packard OfficeJet...
It keeps saying i have a paper jam what should i do ive tried everything
Have you removed the ink cartridge and peeked in there with a flashlight? Sometimes a shred of paper is hung up in there and can be a pain to remove. UNPLUG the printer before you poke around in there. And if your printer has a back door or two, a flashlight beam in there can sometimes show you a bit of missed paper.
Jan 13, 2011 | Office Equipment & Supplies
Paper jam in hp psc 1210v all in one printer/scanner/copier
Check for any obstacle in the Outlet of Printer or Paper input area
Which dp size paper u r using try with different photo paper
Jun 01, 2010 | HP PSC 1210v All-In-One InkJet Printer
I got a paper jam. I can not get to the paper. I see a small bit a paper but I can not get to it. I can not open the rear access panel. I can not pull the jam from the front. How do I clear the jam out?
I removed the cartridge, pulled out the skewed paper and it ripped leaving a very small piece behind. This continued the notice 'paper jam'. I had to remove the two side springs, remove the two star headed screws nearby the springs and prise up the grill to remove the paper shred. Replace everything and the error message is gone and printer normal.
May 19, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Every time I try to print I get an E3 error, telling me to removed a paper jam. But there doesn't appear to be a paper jam, either at the feed-in spot or in the output area. Help!
good day,
regarding to your technical problem,first thing first try to see if there's any obstacle near you printer exit slot that blocks the paper you are printing,,it creates paper jam...
regards,
kaybicks
Feb 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Had a paper jam, removed paper, printer still says paper jam & won't continue
Open up the printer again and carefully check the edges of where the paper flows through the printer, its likely there's a tiny shred jamming a sensor somewhere.
Oct 12, 2009 | Dell 1710n Laser Printer
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
The printer had a paper jam, so I removed all the paper from that was jamed in the back compartment & now it keeps making a strange noise, it won't print & the paper jam message is still lit up. I...
hi
This can be caused by even a very small shred of paper or other debris anywhere in the printer.
Giving u a link ,plz chek tht site nd follow the instructions,hope u willl b helpfull
http://www.ehow.com/how_113761_clear-printer-paper.html
thankyou.
May 08, 2009 | HP PSC 950 All-In-One InkJet Printer
57 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
