Question about Garden
Westwood transmission belt 1688,2281110A how do you fit it to westwood blazer 1994. AS1010
  • malcolm_star Aug 22, 2010
    Hi
    I have manage to change the belt but the machine as two idler pulleys and i am not sure how the belt runs a round them. is there any way you could advise me on that.
    Machine is running and cutting but the clutch/brake now seem to work in the opposite way that it did before if that makes any sense to you.
    Thank you for your advise which you have sent , the whole thing now makes a bit more sense
    Malcolm
Contact the Westwood tractors support team and they can help you with the correct installation of your transmission belt, click on the link below to get started
http://www.westwoodtractors.com/ww_contactsup.html
Posted on Aug 23, 2010
  • 857 Answers
Try these steps:
There are usually two belts; one for the deck and the other is called the drive belt. It sounds like the drive belt failed.
Both the drive belt and the deck belt run off the engine by way of a double pulley on the end of the engine shaft. I'm hoping that you're nodding your head right now. That takes care of pulley #1 for the drive belt.
The second pulley is the idler pulley. Its job is to ensure that proper tension is maintained on the drive belt so it does not slip. If your tractor has a manually controlled release, the idler pulley will pivot when the clutch/brake pedal is depressed and the tension will decrease to a level that allows the tractor to sit still. If your tractor has an electronic clutch, the idler pulley will not move when the pedal is depressed and serves only to maintain proper belt tension.
The third pulley is usually on top of the rear axle and supplies power (torque and speed) to the input shaft of the gearbox. If you have a hydrostatic transmission, the rear pulley drives a pump. What's the difference? A hydrostatic transmission doesn't have a gearshift. It only goes forward or reverse depending on how the pedal is depressed.
If you have the mechanical (idler) style, make sure that the clutch Paddy is depressed fully and locked before attempting to replace the belt. Loosen any belt retaining devices (bars or covers) and slide the new belt on.
I haven't had to replace the belt on my hydrostatic tractor (with electronic clutch) yet, but I'm sure that it has an idler pulley too. Most belt-driven systems do. Good luck!
Posted on Aug 22, 2010
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Sydney phone number for Graham Westwood (northern Beaches)
go phone numbers on google and type in the details
Aug 06, 2016 | Cameras
Westwood t1600
It appears you need to post in another location. Most hard drives do not have gear boxes.
Jun 15, 2014 | Computers & Internet
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Can't connect to westwood servers on red alert 2
Make sure to have you copy of windows as well as your copy of Red Alert 2 fully up-to-date
Thanks Live-Tech
http://www.mylive-tech.com
Jan 03, 2010 | West Wood Studios Command and Conquer Red...
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Oct 03, 2009 | Garden
Garden Logo
709 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
