Question about GE Kitchen Ranges
The oven will not keep correct temp. What do I need to replace?
  • 139 Answers
Replace the oven thermostat or take the temp knob off. look on the backside of the knob. you can adjust 50 degrees each way you need to know the exact oven temp to adjust this right
Posted on Aug 22, 2010
My oven temp is not keeping correct temps set at 350 and acutual temp cooks at 325?? problem correction?
Hey friend, I appreciate your post!
It sounds like your Frigidaire oven could need to be calibrated. If could also be an issue with you thermostat or control panel. In order to properly calibrate your oven you would need to seek assistance from a professional. I would also recommend seeking assistance from a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Oct 04, 2014 | Frigidaire Ovens
Lg lst5651sw problem
One burner is out either the top or bottom.
Nov 04, 2013 | Kitchen Ranges
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
I have an amana acs 3350 that keeps shutting off when it gets hot. The tips i research tell me that either the fan is dead or the door is not shutting correctly. The fan would cool down the control board?...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 30, 2011 | Amana ACS3350AS Gas Kitchen Range
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Oven burns things, very hot on bottom
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Dec 21, 2009 | Frigidaire FEB27S5A Electric Single Oven
I have an identical problem with a FEF352CATB.
There is a possiblity the oven thermostat may have to be repaired or replaced
Sep 01, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Temp on oven is not correct
Good Evening.
I would make sure that the conversion kit was the correct kit for your stove. Also, if it is not heating properly I would call the gas company and tell them the conversion did not work and they need to double check their work (at no charge). If everything is in order proceed to the next step below.
You can try removing the Oven Temp control. There is an adjustment on the knob which will vary the temp + or - 75 degrees F or so.
Procedure: Preheat your oven for 350 degrees F. Give it a good 1/2 hour to 45 minutes and then pull the knob off (usually held on with a set screw) You will need a thermometer that will go up to 500 degrees (I use an electronic one but you can use any kind as long as it is within the ovens temp range. If the oven is underheating simply turn the oven control stem to a higher setting, say a 50 degree incrament. Wait another 1/2 hour and measure temp inside oven. Keep in mind when you open the oven door it affects recovery time, etc so 30 minutes between a measurement and adjustment should suffice. Once you have adjusted the temp control to your target temp of 350 degrees look on the back of the knob and see if there is a stop adjustment. There is a chance the temp control knob could be setup differently but the same philiosphy/procedure will be similar.- the adjustment could be on the stem itself instead of the knob.
Also keep in mind that the oven temp will fluctuate from high to low as it tries to adjust to the temp it is set at. That is why it is very important to give the oven time to cycle low to high when you incrament the temp control. Hope this helps and good luck! Gary
Mar 14, 2009 | Whirlpool SF325 Gas Kitchen Range
Oven wont heat up to temp set
You will need to have the thermostat looked at or replaced, it may be defective and not reading the correct temp, also try using a manual oven thermometer to check the actual temp in the oven to give you a better idea of what the actual temp is inside
Jan 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Kitchen Ranges Logo
169 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
