Question about Magic Chef Ovens
Oven doesn't maintain the correct temperature.
    Guru:
  • 310 Answers
The first suspect is the temperature sensor or oxidation on it's wiring connector pins. If you have an ohmeter you can measure it. It should be about 1080 ohms at 70F. As sthese ovens get older the control board tends to develop problems that cause this behavior. You can have the board rebuilt at fixyourboard.com.
Posted on Aug 20, 2010
My oven is not maintaining temperature
check the door gasket is in good condition.if the door is closing fully properly.check the ground level.
Apr 13, 2014 | Frigidaire Ovens
Model # 36275621302 stove not maintaining proper temperature. Takes long to bake. Broiler comes on ok. Bottom burner gas comes on and ignites in preheat but then the igniter glows hot but the gas doesn't...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oct 28, 2010 | Kenmore Ovens
Oven gets up to correct temperature but sometimes fails to maintain temperature. [does not re-light sometimes] sears kenmore model #362.75621300
sounds as if your bake igniotr has gone , or is going bad, if you remove the lower tra in oven cavity it will expose the "glow coil ignitor" after removing the power source you can unscrew and remove the ignitor form the burner bar and bring to local repair company for replacement ignitor, 50-90 bucks depending on which part it is, essy enought repair
Oct 13, 2010 | Kenmore Ovens
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Oven switching off
Hello, this is a commom problem. The cooling fan is not working correctly and you need a new controller. The part number is 8996619267611 and costs about £28.00.
Nov 11, 2006 | AEG B1180-4 Electric Single Oven
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
