Question about Xerox 3001 Copier
I put toner in and the low toner light keeps comming on and won't let me print. J1 keeps comming up what should i do?
    New Friend:
  • 51 Answers
Disconnect the toner sensor jack from back side of developer module and make copies
Posted on Dec 12, 2010
Why does the low toner indicator keep coming on, along with the J1 code, when I just put a new one in?
There is a low toner sensor in that machine that gets impacted with toner then doesnt work correctly. It uses sound waves to detect the toner, and once it gets very dirty it no longer works right. It will need to be removed and cleaned.
Aug 19, 2010 | Xerox 3001 Copier
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
J1 Error, Changed a brand new factory-sealed toner, still getting J1 Error
Make sure you have the right code: J1 or J2.
one is for the drum and the other is for the ink.
Make sure the toner unit is for this model and not for a different model.
If the old modual is still available, check the connectors at the back and see if they are the same.
If anything else Call Xerox for repair. If the cartridge was bought through Xerox have your reciete available for warrenty.
If repairs still need to be made, A Xerox service call may be needed in order to fully repair the copier and warrenty the cartridge.
Nov 06, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre Xl2130f copier printer error j1
that is the message for low or out of toner. What you are doing by tapping it is just lostening the reemaining ink in the cartridge. If the cartridge is new, have it replaced where ever you purchased it because most likely its defective.
Oct 02, 2008 | Xerox WorkCentre XD120f Copier
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
J1 code Xd100
a J1 means that you are low on toner, try another toner cartridge.
Jun 04, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
J1 error code
J1 is detecting either a low or out of toner condition.
Maybe just need to have the cartridge shook, replaced or it could lastly need the toner sensor replaced.
Mar 07, 2008 | Xerox 3001 Copier
Keeps showing J1 error, toner light is flashing
The J1 error means the toner cartridge needs to be replaced. Since you just replaced the cartridge, you should remove the cartridge and repeat the following steps.. Shake the new toner cartridge horizontally four or five times and then remove the cover. Slide the new toner cartridge in until it locks in place. It sounds like the cover may still be on the cartridge.
May 14, 2007 | Xerox WorkCentre XD103F All-In-One Laser...
XD103F copier keeps showing J1 error, toner light flashing
J1 means paper jam...so find it where the paper jam ecsactly...thanks
May 14, 2007 | Farenheit DVD34 Car DVD Player
Xerox 3001 Copier Logo
189 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
