Question about Braun 8585 Electric Shaver
I need a replacement battery for my BRAUN 8585 shaver. When (if) I manage to lacate a battery I will need instructions on how to replace the battery.
  • Braun Master
  • 1,625 Answers
You will find compatible battery type at shaveroutlet.com. See link below. Be sure to read the NOTE on the page concerning installation
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
If you are not able to solder in new batteries, you may want to simply buy the circuit board that includes the batteries. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
To disassemble the shaver, first remove the 'cap' on the bottom that surrounds the hole where the cord plugs in by gently prying it off with the tip of a small flat screwdriver or similar object. Once removed, the side grips simply pull off revealing 4 screws on the back. Remove the 4 screws to remove the back cover and access the insides. Reassemble in reverse order.
Posted on Aug 21, 2010
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
How to Reset Battery Braun 8585
You will find videos for dismantling the shaver as well as replacing the batteries at shaveroutlet.com. See link below for correct replacement battery type and videos
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
Mar 23, 2013 | Braun 8585 Electric Shaver
My braun 8585 needs new batteries. how do a change them.
You will find compatible batteries at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for helpful tutorial videos
Jun 05, 2011 | Braun 8585 Electric Shaver
Hello. My Braun shaver 8585 model charges and the blue light comes on BUT whne shaving, it seems the motor dies quickly
This is a typical symptom of batteries that have passed their useful life. To restore the shaver to it's previous charging capabilities, you will need to replace the batteries. You will find correct battery type at shaveroutlet.com. See link below. You will need to order two
Scroll down item page for helpful video concerning installation
Jun 03, 2011 | Braun 8585 Electric Shaver
I have a braun shaver 8000 series. My problem is that it does not charge anymore. I also tried to connect the plug directly to the shaver but there was no power. Is it possible that the rechargeable...
The problem you've stated about your Braun model 8585 is related to old batteries. If the charging light still illuminates when you plug it in, you can simply replace the batteries which can be found at the link below
https://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
If it completely dead (no light), you will need to replace the circuit board instead. See here:
https://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
Video instructions are here:
https://www.youtube.com/watch?v=D6jRpCnB8T4&list=PLfFUuDEned17Mmy77GMgjiyvnXAPdQBeV&index=5
https://www.youtube.com/watch?v=2oAnLpvdYqQ&list=PLfFUuDEned17Mmy77GMgjiyvnXAPdQBeV&index=1
If you are not equipped to do this repair, contact shaveroutlet.com for repair services
Aug 05, 2017 | Braun 8585 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
Jul 31, 2010 | Braun 8585 Electric Shaver
How do I open a Braun 8585 shaver to replace the battery?
You will find batteries at shaveroutlet.com. See link below
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 13, 2010 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
850 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
