Question about Stairmaster 4600PT Stepper
Left peddle just dropped to floor. assume it has disconnected from chain
    Problem Solver:
  • 5 Answers
Sounds like the spring thet is connected to the chain brock
Posted on Aug 20, 2010
How do i bleed clutch on 2000 trans am ws6 ram air
I\'m assuming this is the one with the 5.7L LS1 V8. Ok, bleeding the clutch is real no different than bleeding your brakes. Locate our slave cylinder.(Not the reservoir) In most cases, it\'s best to start with a gravity bleeding. Make sure the reservoir is full, loosen the bleeder on the slave cylinder, until you have a steady stream coming out. Then tighten the bleeder, and check the peddle.SUCKAUTION**** MAKE SURE THE BLEEDER VALVE IS TIGHTENED AND CAP IS ON THE RESERVOIR BEFORE YOU TOUCH THE CLUTCH PEDDLE!!! AS MISSING THIS STEP WILL **** UP AIR INTO THE LINE.Step 2, have a friend sit inside the car, and continuously pump the clutch(like bleeding brakes) about 10 pumps should do it. Have friend hold the peddle to the floor and announce that it is to the floor. ***They must hold the peddle to the floor*****while they are holding the peddle, loosen the bleeder valve until fluid comes out. repeat process until no micro bubbles come out, just clean fluid. Finally, remember to top off your fluids after bleeding, as you will naturally loose some in the process. Hope this helps. ^^
Mar 27, 2013 | Cars & Trucks
When I start to peddle the gear shifter moves as if im shifting gears and the chain comes off. Any suggestions?
I'm assuming you have levers on your shifter. If so, typically, the problem is the screw on the side has come loose allowing the lever to move. Tighten the screw a little see if it resolves your problem. If not snug it up some more. The tension of the screw creates the friction to keep the lever from moving.
Jan 04, 2013 | Trek 3500
How do i bleed the brakes on my 1984 ford mustang never done it before
same as any nother car. take off mastercylinder cap. get a helper set in the drivers seat. apply pressure to the brake peddle. with a box or tube wrench break the fluid *** on the top of the calliper/back of drum loose. foot pressure on peddle should push it to the floor -hold it on the floor! tighten the *** on the caliper/drum tight-ish. not over tight. then let peddle up off floor. pump till you get resistance/tighteness. hold pressure on peddle, loosen *** again and peddle will go to floor again tighten ***, lift up peddle pump for pressure. repeat untill all air is out of line/ or fluid runs out clear. never let the master cylinder get low on fluid. have plenty on hand. repeat for all 4 tires.
Aug 10, 2012 | 1984 Ford Mustang
The chain keeps coming off when coasting or peddling backwards. what adjustments do i need to make?
Assuming it's a derailleur-equipped bike,
All adjustments...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
It also helps to know how to shift and avoid gear combinations that stress the drivetrain or allow too much slack in the chain...
Google "how to shift a bicycle"
May 30, 2011 | Schwinn Cycling
I need to get the clutch cable off a 1997 vw cabrio.How do i get the cable off the clutch pedal
After disconnecting the cable from the engine compartment remove the lower panel on the driver side. Press clutch peddle to floor then reach around the steering wheel column on the gas peddle side. you will feel a plastic guard. reach under guard you will feel the cable on top of clutch peddle. pull cable up and toward back of car.
Feb 13, 2011 | 1999 Volkswagen Cabrio
Brake peddle goes all the way to the floor. brake peddle will have pressure when the car is off, but when you turn it on brake peddle loses all pressure. how can i tell if its the master cylinder or the...
first make sure there are no brake fluid leaks, sometimes the steel lines get rotted and start leaking. to test the booster with the engine off pump brake pedal about 10 - 12 times on the last pump hold the brake pedal down and start the car if the booster is good the pedal will drop alittle.
Feb 02, 2011 | 1994 Oldsmobile Cutlass Ciera
The clutch peddle went to the floor when i pushed the clutch peddle in
Check the floor by the clutch peddle if it is wet (you may need to look at the very top of the peddle)than you problem is the clutch mastercylinder
Jan 31, 2011 | 1994 Nissan Pickup
When the bike is peddled there is a clicking sound. Is this normal? The bike hasn't been used for about a year.
I think the clicking noise is caused by one of two common issues. The easiest is that the little black computer pickup is too close to the magnet located on the right plastic piece on the right side of the wheel and everytime the wheel makes a full circuit while peddling, that little black piece clicks as it actually hits the magnet. If that's the case, then pull the black magnet sensor away just 1/16 of an inch aways so it will not hit the magnet everytime it passes the magnet. You can tell what's causing the clicking noise by getting on the floor and pushing the pedal around with one hand slowly and looking closely at the tow places I will mention to determine where the clicking noise comes from and then making the adjustment to stop it. the other place the clicking can come from is the chain rubbing against the metal on the left side. It might be hitting the TOP of the metal cage when cycling OR the BOTTOM of the metal shield which covers the pedal assembly. Look closely at the left side of the bike while peddling the bike slowly to see if the noise is metal against metal. You can shift the cage slightly to take the pressure of the cage from scrapping the chain by sitting down in front of the bike facing the cage and placing both feet onto the left & right supports (they're what hold the bike up) and you grab the little black wheels on both sides with your hands and push down slightly but firmly to shift the cage a bit and it will move up or down depending on where the chain is scrapping it when you cycle. That cage will shift slightly over time and it can make a loud noise when it scrapes the chain. I hope this helps. If not, give me a reply with more details and I'd be glad to help you isolate and fix the problem. Leave postive comment on fixya if you like my solution. Luke terpcafe@yahoo.com
Jan 16, 2011 | Schwinn Original Airdyne
Stairmaster 4600PT Stepper Logo
97 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
