Question about Mercedes-Benz GPS
My daughter borrowed my wife's 2002 E320. She went jogging and opened the gas cap door, locked the car, then put the keys in the gas cap door and closed it! A locksmith opened the car door for her, but could not open the gas cap door or retreive the keys. Is there a way to do this?
  • jtsolari Aug 20, 2010
    I am hoping to find a solution that does not require prying the gas cap door with a screwdriver
  • 2,272 Answers
If you peel back the inner lining of the trunk, on the gas cap side you can get access to the gas tank cap.
Of course that requires your trunk to be open.
press your finger exactly in the seam on the right-hand side and it will open. Press anywhere but that exact location, and the door won't budge. Make sure all the door locks are open. If they are, then just press the left side of the gas cap and it will pop open. ----------- The gas filler flap opens by pushing in on the front edge of the flap. This will pivot the door open from the rear edge. If this does not work, you should still be able to get it to rock, and see the little pin in the middle of the rear vertical seam between the flap and the fender. Try starting the car and cycling the locks by pulling the button up and down on the driver's door, then, with the car still running, see if the flap will open. If not, the actuator is likely shot --------- You can manually disconnect the lock by moving the plastic liner in the trunk on the passenger side and looking up behind this liner just below the trunk spring. There is a rod that goes to the gas filler flap area, and if you pull this aft you will unlock the flap. You need to check to see if the rod stays in that position (it should, but may not depending what the failure mode was). If the rod wants to go back into the lock position, you will need to hold the rod in the unlock position with one hand (left) and open the flap with the other, or get a little help from another body. In some cases disconnecting and reconnecting negative cable of battery helps to get the gas cap door open.keep the battery terminal disconnected for 30 minutes then reconnect it and recheck/. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 20, 2010
  • 332 Answers
I suppose the gas cap door should be where you put fuel to the car (but why would she do that). Well, i think the security of the car has been activated, so you would need to contact a Mercedez Expert to assist you.
Best regards
    Brigadier General:
  • 5,158 Answers
Sounds like it is jammed. wrap some soft tape around a screwdriver so you do not damage the paint. gently turn the screw driver blade sideways in the space opposite to the hinges till the door moves slightly sideways.then gently to the right or left ... whichever is opposite to the hinge. it should open. failing that you may very well have to pry it open with some force and replace the door later as the car isn't much use if you can't access the fuel filler.
LOCK MY KEYS IN MERCEDES S55O
Sorry I went to bed about the time you posted. From what I saw on the internet a lot of people with this car lock their keys inside. I would call Mercedes and get the key code and have a plain metal key made by a lock smith or Mercedes to unlock door only then like I did I put this key in my wallet with duct tape. I already had to use it once
Jan 10, 2012 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
2005 Lancer - interior lever does not open the access door to gas cap. How do I fix it?
...Check the flat spring that kick the gas cap cover door open, two plastic holding the spring on the either side must missing, try any plastic and glue it there to not lost again and put some lube at the door hinge and the key bolt, they will pop open wide..
Aug 15, 2011 | 2002 Mitsubishi Lancer
My gas cap and trunk wont open. I need gas. Te button on the console won't release the gas cap to open or the trunk. Audi TT 2002.
Take your key and go to the drivers door, make sure the door is unlocked by pulling on the handle, open and close the door. Insert the key and "lock" the door, double check that it is locked by pulling on the handle. Insert the key and "un-lock" the door, use the handle to open the door and now press the fuel door key and it should open, same for trunk release button.
Audi's are a strange breed, sometimes you just need to "re-set" some stuff. But in the future if you lock the car with the key, the fob will unlock the car but the three buttons in the console will not work, the fob will function correctly.
I hope this helps.
Feb 27, 2010 | 2002 Audi TT
My wife is stuck at the airport. the key fob on
On the driver's side door handle, there is a cap covering the key hole on the right side. On the bottom of the cap is a small ****. Use the valet key to pry it up and off. Then you may open the door, most likely sounding the alarm, so you will need to insert the remote in the ignition to stop the NOISE!!!! Hope this helps. This is how I lock my remote away when I go somewhere to run.
Nov 06, 2009 | 2006 Volkswagen Passat
1995 Mercedes Benz E320 Wagon, How do I reset the Anti theft so I can start the car. My daughter is stranded right now please help
1. Lock doors via key on Driver's door.2. Disconnect battery.3. Wait a couple minutes to let remaining voltage leak out of system.4. Reconnect battery.5. Unlock doors via key on Driver's door.
Oct 30, 2009 | Mercedes-Benz E320 Cars & Trucks
2002 Porsche Boxster My key battery went dead;
do I need a a microship in my porsche key?
Aug 20, 2009 | Porsche Boxster Cars & Trucks
Gas door is locked and don't know how to open
Open the holstery in the trunk, you will find a pull ring, just pull it and the gas lid will pop open.
Alf Pousar
Aug 01, 2009 | 1994 Volvo 850
How do i open the gas cap so i can put gas in? it's not by the seat, drivers no where how do i find out...i cant the cap..where is it?
Not sure where the release is but sometimes you can find a manual override cable in the truck that will open the door.
Jun 28, 2009 | 1991 Mercedes-Benz Mercedes Benz Sl Class
02 toyota camry key won't open doors & car is making click sound
called the Toyota Service department Monday morning and spoke with their tech. Needed to use spare key. Other key was worn out.
May 18, 2009 | 2002 Toyota Camry
Can not turn key in ignition to the start position.
sounds like the brake pedal lock out switch or the gear selector switch is out of adjustment.
Feb 22, 2009 | 2007 Chevrolet Equinox LS New Cars
Open Questions:
GPS Logo
141 people viewed this question
Top Mercedes-Benz GPS Experts
D. E. Hev
Steve from Oklahoma...
Level 1 Expert
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
