Question about GE Energy Star WCVH6260F Front Load Washer
Front load Washer
WCVH6260F Front Load Washer. you set on any cycle it locks door does entrapment cycle as explained manual after 2-3 minutes says door locked and start/pause button is blinking. when you again say start it does that initiasl check cycle and again stops with start/pause button blinking . does not go to actual wash cycle. I have already purchased a new lock assemblely and it does the same thing
    President:
  • 1,294 Answers
You have to clean-out your inlet hoses; the hose/s external of machine, the screens. You may not be getting sufficient water.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on May 31, 2008
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Mar 14, 2010 | GE Energy Star WCVH6260F Front Load Washer
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Oct 02, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Won't turn back on and finish cycle
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
Mar 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
206 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
