Question about GPS
Viper 560 xv car alarm. When I use remote unlock, the horn blows intermitently. Not always but usually if car sits for a hour or so. When horn triggers I put key in ignition and turn fully on and then off 3 times in 5 seconds-good to go. When I arm system with remote, lights flash once-ok. (chirps are disabled). When I use remote unlock/disarm, lights blink twice, but on one occasion they would blink 3 times.?? When I use remote lock/arm , blue led flashes 6 times then pause then 6 times. If I come back in a while the blue led seems to be blinking steady once a second.
SOURCE: Magellan GPS 310
to reset the unit hold down the right arrow while turning it on this fixed mine!
Posted on Aug 21, 2006
SOURCE: Ademco Alarm System - Zone works opposite? Triggers on (door closed)/ Stay Off (door opened)?
i dont think it polarity not unless alarms in the usa are different from nz aus uk sounds like you have a faulty something. try open and closing the front door and look at the keypad to see if the zone activates as it should. there can only realy be 3 things. device, cable or panel fault. you can easly test the system by swaping the zones in the panel ie zone 1 to 2 and 2 to 1 providing that they have similar zone charectorists ie "entry exit" if the fault moves to the other zone you know its a device fault.(inspecting the cable for damage is probably the easy thing to do) if its a reed switch you could look at the position of the magnet it may be making borderline contact and a slight movement of the door could be tripping the zone. if the fault doesnt move its a panel fault. before you jump in though make sure that if you dont comprimise your protection or insurance by trying DIY security. good luck (if you have no joy post more details)
Posted on Dec 14, 2008
  • 29 Answers
SOURCE: Plenio VXA-3000 Navigation Unit, powers on but screen stays off.
If you Need Plenio Tech Support
www.dvssale.com
Dan Kim 408-970-3388 office
DVS Sales Inc.
2398 Walsh Ave.
Santa Clara, CA. 95051
Email kimus@dvs.co.kr
posted 01.15.2009
jeffreydrescher@Bellsouth.net
Posted on Jan 15, 2009
  • 43 Answers
SOURCE: I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Posted on Apr 01, 2009
SOURCE: uniden vs1100xr car alarm will
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Posted on Apr 18, 2009
I have DRL on my car and with the factory alarm remote when you press either the lock or unlock the head lights or the parking lights come on. With my Viper 2 way remote no lights come on when pressin
The Viper alarm (and most other alarms) are designed to be connected to the parking lights.The headlights are not meant to be flashed continuously, as when the alarm is triggered. If you want the headlights to activate with the alarm then, the parking light wire from the Viper needs to be connected to the headlight wire instead. NOT RECOMMENDED.
Although the Viper alarm may or may not have a horn output (you didn't mention the model) ,it can be connected and it can be programmed to sound either when the alarm is triggered or all the time(depending on the model).
By the way, the Driving while Running Lights are seperate from the Sentry Illumination Lights. The Sentry Illumination Lights are designed to illuminate the area in front and around of the vehicle before and after entry. They can be programmed for the time that they will illuminated before and after entry.
Aug 25, 2012 | Remote Start System
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Jan 08, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote stopped working!
First things first. Check the fuse that powers your alarm system. If that seems to be ok then try the next simple option. Open the hood and disconnect the negative battery cable. Then turn the ignition to the start position for approximately three minutes. This will allow for any remaining energy to dissipate from your system. Now you can reconnect the negative cable. *** Before trying your alarm *** turn the ignition on and off 3 times quickly. Make sure you don't start the vehicle. Now you can exit the vehicle and try your alarm. FYI you can always stop at a nearby Best Buy store for additional assistance. They are usually very helpful. Good luck and best regards, Rico...
Sep 13, 2009 | Viper Security and Remote Start System...
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Car is completely locked down
Let's hopethat the installer actually put in the valet switch for the Viper! Lcate the valet switch. ALWAYS put mine down by the e-brake lever under dash. (I assume that the alarm is going off? If not, go to next step.
Find the alarm/start brain under dash. Unplug main 6 pin 12 gauge wire harness. Wait 5 minutes, then re-appy the power plug. Alarm "may" go off, then try again.
Hit me back if you need further assstance. TTYL
Larry T
Winona Lake, IN
Jan 28, 2009 | 791XV The 791XV is a 2-way Security and...
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Viper 160XV Problem
How to programing the remote for viper 160 xv.Thanks.
Jul 02, 2008 | Viper Security and Remote Start System...
GPS Logo
35 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
