Question about Avid Liquid Pro 7 for PC
Video flickers when i have a tilt or pan or zoom shot.. & sometimes giving a green window after exporting the video..
CONTROLLER NOT CONTROLLING CAMERA. AFTER A FEW MINUTES OF TURNUNG ON CONTROLLER AND CAMERA
Did you check your wifi signal level? try first with cable to see if yo are still having a problem.
Tony
May 08, 2015 | Sony EVI-D70 Video Camera; Pan Tilt Zoom,...
How do i adjust the zoom control on the logitech C270 so that i can use the pan and tilt functions?
Do any of you have Follow my face option enabled while trying to use the Pan and Tilt feature? If so, please disable it and try using the Pan and Tilt feature again.
Aug 23, 2014 | Logitech C270 Web Cam
Pan and tilt controls
I had this problem on the Logitech 9000 and found it was due to the "Follow my face" option being checked. As soon as I unchecked it the zoom, pan and tilt controls worked.
Jul 01, 2012 | Computers & Internet
Im trying to control a cyberdome select 18x . i get control from the dvr software but when i zoom in it zooms all the way in and wont zoom out.it pans and tilts fine. is there a reset and i need a dip...
Have you tried the dipswitch located by the UTP output? You should switch 3 & 4 to off if the signal needs to loop to other devices and switch them to on if this is the only device on the data signal bus or the last in a chain of devices on the bus. dipswitches 1 & 2 aren't used.
Jul 29, 2011 | GE Security Cyberdome Hd 18x D/n Ptz...
I have a sunpak ap-200w with a infared remote. I changed batteries and it lost the zoom control but has the pan and tilt. Can you tell me how to regain the zoom control?
I have 2 of these but have NO remote to operate them. I'll give you one of them if I can use YOUR remote to collect the IR code or program a universal remote so I can use the one I'll have remaining.
Nov 15, 2010 | Sunpak V-Remote Remote Control
Cant connect to SNCRZ25N via browser.
SNC-RZ25N Sony Network MPEG4 Pan-Tilt-Zoom Color Security Camera ... the SNC-RZ25 is the perfect MPEG-4 PTZ network camera for your remote ..... Sony Security - IP SNCRZ25N network ptz camera with 340 degrees pan, ... 1 2 3 next ... they do not reflect our opinions and we have no responsibility for their content.
Mar 27, 2009 | Sony SNCRZ25N Network Camera Snc RZ25N
Picture shakes when I zoom
I don't know how you can easily tell the spec for the anti-shake is working on your camera. There is a specific specification for how much it can compensate. There is a factory spec that specifies that with a specific lens magnification ratio, the camera can be moved a specific number of arc-seconds and display within a specific amount of movement error. At home it would be impossible to do a technical evaluation of this feature.
What you can do as a user is to read the instruction manual about the option and see how to make sure that it is turned on in the camera's menu section. It is possible that your model may not have the feature. This you have to check in the spec sheet that came with the camera.
When the anti-shake is turned on, you should see the picture appear to be more stable than when it is turned off. With high zoom settings, it will be less stable looking than with wider angles of zoom. It does have its limitations.
Professional photographers normally don't like the anti-shake feature for shooting videos. For still pictures it is a good feature if you want this type of performance. This is because with moving video taping when the camera is being panned in small motions, the smoothness of the pan is taken away. The stabilizer starts to work at the beginning of the pan and then it gives out in sort of stepping actions. This can create a sort of jerking type of pan motion in the pictures.
Jerry G.
May 02, 2008 | Sony Handycam CCD-TRV318 Camcorder
Avid Liquid Pro 7 for PC Logo
Top Avid Computers & Internet Experts
Michael Galve
Michael Galve
castletech
castletech
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
