Question about Samsung DualView TL220 Digital Camera
Samsung TL220- Blurry screen and blurry photos ever since I zoomed in. Will not go back to normal.
Nickstar19
  • 417 Answers
SOURCE: Lens keeps moving in and out, plus, the screen is blurry
FAULTY OR ITS NOT WEATHER PROOF
Posted on Jul 03, 2008
SOURCE: samsung digital s73 camera
my card is locked - I keep getting a message "card locked" how do I fix this?
BHG
Posted on Jul 29, 2008
wicabuss
  • 48 Answers
SOURCE: blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Posted on May 01, 2009
iwctoys
  • 126 Answers
SOURCE: FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Posted on Jul 02, 2009
  • 11967 Answers
SOURCE: Stuck Lens
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 13, 2010
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
When i save the pictures i had used for a project come out blurry when i try to zoom them in.
Usually they will go blurry if the photo resolution is too low.
You can only zoom in to detail that is actually there, then it will just blur or pixelate
Jul 14, 2010 | Computers & Internet
The picture on my samsung tl220 is comming out blurry why
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there
is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Apr 05, 2010 | Samsung DualView TL220 Digital Camera
When i press the on button camera makes a buzzing sound but does not switch on. previously it has been taking photo's but they are blurry.
Your Camera is either out of battery of uncharged.The buzzing sound is the sound it makes when the camera zooms in,most cameras automaticly do this when started up.The reason for your pictures being blurry,could just be off focused.Hope it helped
Oct 10, 2009 | Samsung Digimax D73 Digital Camera
I have a new polaroid I735 camera and the pics are very grainy and blurry even when viewed through lcd screen. Any ideas?
maybe you zoom in a lot and then it would be normal and if the pictures come out fine, i wouldn't worry about it but if the print pics come out grainy and blurry i would take it back if you have warranty
Aug 03, 2009 | Polaroid i735 Digital Camera
Blurred images on the lcd screen and pics come out blurry
Apr 30, 2009 | Samsung S860 Digital Camera
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Cannot Zoom in or out
I took the battery off and then put it back on and when I turned it on it worked fine! Thank you
Jul 03, 2008 | JVC GR-D250 Mini DV Digital Camcorder
It became blurry
Are you using the auto function on the disc on top? If you are not it may be that your lens is open for too long.
I often get the same problem when using any other option as I'm not a pro, and when I zoom in very close on something far away.
Dec 06, 2007 | Samsung Digimax S730 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Samsung DualView TL220 Digital Camera Logo
162 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
