Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side Model GSS22JEMB WW. It was in the house when we bought so it was probably purchased when the house was new in 2001. For the past two years we have heard a screeching/groaning sound on occassion coming from it. We just thought it was the ice maker. Last night we noticed the ice cream was soft and there was frost on the inside of the back wall. I turned the thermostat to 0 and left it that way overnight. I turned it back on this morning and it seems to be cooling. Any ideas to prevent future problems?
  • GE Master
  • 909 Answers
That screeching noise you are hearing is the evaporator fan motor that is found in the freezer section behind the panel. If it is screeching, it means the motor is slowing down to the point that the ice can migrate up to the motor and ventually stop it. After defrosting properly(12 hours), remove back panel(in the freezer compartment) carefully aprox 4 screws. carefully pulling pannel out you will either see the motor on the panel being pulled out or fixed above the evaporator, screwed onto the fridge body. Remove and replace it with a new one. You can get away with it on a temporary repair by spraying Q20 (a solvent) to lubricate the motor shaft. Can sometimes last for months.Reinstall in reverse. Note, please remove plug from the wall Thanks.
Posted on Aug 20, 2010
My ge side by side model #gss20ieta ww freezes up what could be the problem
Probably a fan or the defrost heater, either are inexpensive to fix. Dont get ripped off.
Nov 21, 2013 | GE Refrigerators
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
I have a GE side by side ref. model # GSS22JFMC WW that is not cooling. A few months ago I replaced the defrosting element. It is not freezing up but for some reason it sometimes stops cooling. I can turn...
First this refrigerator has very low consumer rating. They are plagued with problems with very poor company backing. But without be able to diagnosis the problem in person I would say it's the mother board. And you may find that GE has a new updated board for your appliance. I would go to Amazon.com and search for your motherboard for your refrigerator and read the reviews. Some people leave some great idea. Plus it you bought this refrigerator brand new you can fight with GE to send you a new board.
Oct 29, 2017 | GE GSS22JF Side by Side Refrigerator
GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubic feet in a GE MOdel TFX22KRCE WW
If there is nothing inside the refrigerator that will tell you its cubic feet, you could always calculate it on your own. See this link:
http://www.ehow.com/how_4530599_find-cubic-feet-refrigerator.html
Jun 17, 2009 | Computer Gear Fridge Gears Puzzle
GE model bsy25gfmd ww has power,lights and ice make have power and fan runs, however compressor will not "kick on"
You can try changing your relay/overload, it is on the side of the compressor. If that does'nt work you probable need a new compressor.
May 12, 2009 | Refrigerators
Side by side refrigerator problem GSH25KGRB WW
I have the same problem with my GE fridge.  I inherited the fridge with the purchase of my house.  There is a coil located in the back of of the freezer.  Remove the wire shelves and remove the screws and remove the back panel inside of the freezer.  I can almost guarantee your coil is completely iced.  I just use a hardryer to remove the ice.  I need to perform this once every four weeks.  It's a bummer.
Jan 02, 2009 | GE GSS25LGM Side by Side Refrigerator
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
GE now charging $75+ for answers
well i dont know if you still need help or you already solve it. when i repl repl the ice maker it works on all GE'S you probalbly bought part #wr30x10061 right that is all you need some older model have diferent ice maker that were mechanical this is an electrocnic ice maker is ok if you just repl it just use the extension if you need to coonect the wire harness
Jul 09, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Model GSS22JEMB WW - Defrost heater Bad
yes, remove the freezer panel and defrost with blow dryer. will work for about 5 to 7 days.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
165 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
