Question about HTC Droid Eris by
My startup screen is frozen on my droid htc. i have taken the battery out several time and tried to rebot it.still wont come on goes back to the three droids with skateboards. how do i fix.
  • 21 Answers
There must be an application creating that prob. most probably a third party software u have installed. u have to hard reset ur cell phone. consult user guide of ur cell for instructions
Posted on Aug 20, 2010
The phone won't turn on (or off)
I have a Droid Razor (you can't remove the battery) that did something similar about a year ago. If you turned it off, it would only turn on when it was good and ready. No matter how many times you pushed the on/off switch.
I took it to the Verizon store, it did it one time for him to see, then, we couldn't get it to do it again. It hasn't done it since. He noted it as being in the warranty period so that I could get it replaced if it came back. It never did. It will be time to upgrade it in May.
Mar 01, 2014 | HTC Cell Phones
HTC stuck on HTC screen...wont start
I would try flashing the kernel separately via fastboot and seeing if that helps
Sep 27, 2012 | HTC 7 Surround Cell Phone
How do I reset my HTC incredible to factory settings?
Please note that all data will be deleted from the HTC DROID Incredible as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC DROID Incredible is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Hold the Power button until the display turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button to select
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC DROID Incredible. Once the wipe is complete, the phone will reboot to its factory fresh state.
Mar 08, 2012 | HTC Cell Phones
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
PLease do a hard reset on the phone and here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 04, 2011 | HTC 7 Surround Cell Phone
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 | HTC G1
My droid eris is frozen htc.how can i get to work again.
Try pulling the battery out for at least 15 seconds and the put it back in and reboot.
If that doesn't work, try resetting it by holding the volume down button and the Send button, then while holding both those buttons, press the End key.
If worse comes to worse, go to the Verizon store and see if they can help.
Feb 16, 2011 | HTC DROID ERIS Cell Phone
My htc driod eris is frozen and I remove the battery and still frozen won't start
my htc eris only boots up to the fast boot / H boot / bootloader menu. Its frozen... none of the buttons move anthing. I have to take out the battery to get it to power down.
Jan 22, 2011 | HTC Droid Eris by
My droid is on the pattern lock page (i do know what the pattern is) but it wont let me put the pattern in. I have removed the battery and powered the phone back on and the same thing happenes it is just...
You can hard reset your Motorola Droid phone if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Frozen on rebot screen
First reset it to turn it off then do this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Apr 20, 2009 | Creative Labs ZEN V Plus MP3 Player
HTC Droid Eris by Logo
651 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
