Question about ViewSonic Computers & Internet
My 19 inch viewsonic monitor has a black screen... although the LED indicator is in GREEN. I just left it open, without signal. But when I try to use it again, the screen just stays BLACK.
  • 11,361 Answers
Please read an learn about failed monitors below.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 23, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I have a VA1912wb viewsonic monitor (A couple of years old). While playing any movie, the screen instantly goes black though the green light indicator is still glowing. Im able to hear the sounds from...
i think your monitor is going to expired soon , i u have valid warranty then try to contact service center if not then buy a new one LED monitor is best than LCD and LED has more life expectancy and woks very well so bye t.c
Sep 03, 2011 | ViewSonic VA1912wb 19" LCD Monitor
My Viewsonic VA902b monitor screen turns black anddoesnotrespone
That is a problem of inbuilt display card it does not support to games. You have to open the system case and install AGP card in the AGP slot AGP card is available in any shop of computer your other problems will also solve
Mar 09, 2010 | ViewSonic VA902b 19" Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
ViewSonic VA912b monitor fading out during boot
It is probably the power supply, or the inverters.
Similar problem with solution, though it requires you to know something about electronics.
http://www.badcaps.net/forum/showthread.php?t=6876&highlight=*va912*
Jun 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
May 04, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsoniv VA 902 LCD 19" monitor
If the signal cable is detachable from the monitor, you could try with another cable... Regarding the power, I' not an expert, but if you're familiar with electronics basics, like risks of high voltage, soldering, etc, and you'd like to experiment with the unit, then I can give you some hints.
Mar 19, 2009 | ViewSonic VX900 19" LCD Monitor
Viewsonic lcd tv 37"
try to check the RAM, video card, or processor maybe it is not properly inserted to the slot.
Jan 08, 2009 | ViewSonic A90f+ 19" CRT Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
80 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
