Question about Sony Handycam DCR-HC36 Mini DV Digital Camcorder
DCRA-C151 won't connect to my mac even with firewire
My camcorder won't work with our apple mac g5-cs3 computer
The problem is not with the camcorder. The problem is with the capture settings.
You can capture video via firewire or USB. Imovie has a capture mode that syncs with nearly any camcorder. Roxio Toast will also sync with a camcorder. Be sure the camcorder is connected and that the computer recognizes it. It may take a few on-off cycles to sync itt.
Feb 21, 2013 | Computers & Internet
Sony Handycam Model no dcra-c155 USB Not work
What are you trying to do?
Is there a Memoty Card in the camera?
If you are trying to capture footage from tape them USB is incorrect, use a firewire cable to connect.
Apr 16, 2011 | Sony Handycam DCR-HC90E Mini DV Digital...
Not sure what cord to use to connect my mini dv to my mac.
Depends on the Mac unit you have. If your MAC has a firewire 400 port, then use the firewire cable that came with your camera. Just connect the cable to the camera and the other end to the mac. iMovieHD is already loaded - with the camcorder in "Play" mode, you will "Import" the video.
If your Mac does not have a firewire 400 and just a firewire 800, you need an adapter. Click on this link to see that adapter.
Thank you for using Fixya and your generous rating will be much appreciated.
Oct 20, 2010 | Canon ZR800 Mini DV Digital Camcorder
Intermitant failure of the firewire port
It's quite possible you have a FireWire port with hardware problems. The fix is somewhat costly, because it requires a logic board replacement. You need to bring your machine in for service.
Jul 01, 2010 | Apple Mac mini
Uploading video from my Cannon Elura 100 to my MacBook
try using the image capture utility when connected to the computer. canons are notorious for forcing you to use image utilities (picture wizard in windows and image capture in macos). my canon xsi did the same thing.
Jun 01, 2009 | Apple MacBook Mac Notebook
Mac External Connection
Easy, FireWire.
Connect the 2 with a firewire cable. If reading off the laptop, for example, reboot it & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The laptop should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Connecting another Mac to a laptop
Connect the 2 with a firewire cable. Reboot the Mac you want to read from & hold the T key down while it boots up. A large firewire symbol shows on the screen indicating FireWire Target Mode. The other Mac should be showing up as a firewire drive on the other Mac.
Apr 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
There are 2 cables,
  1. A-V Connecting Cable P/N 1-831-553-11
  2. USB Cable P/N 1-829-579-41
attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
PV-GS35 to mac connection problems
Do you have another camera that you can use for testing? If so, try connecting that one and see if you get a picture on the Mac. If so, I'd guess a blown Firewire socket on the camera. If not, try a different firewire cable. If that doesn't fix it, suspect the firewire port on the Mac. If it's a Mac Pro, you might try adding a third-party FW card to the system. If some other type of Mac, you may need to send it in for repairs.
If you've completely ruled out hardware problems, did you upgrade QuickTime, recently? I've seen that that sometimes hoses the connectivity between Macs & cameras.
Jan 27, 2008 | Panasonic PV-GS35 Mini DV Digital...
Sony Handycam DCR-HC36 Mini DV Digital Camcorder Logo
303 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
