I have a 19' view sonic monitor, when i plug it in, the monitor won't turn on, the light on the power button just blinks on and off in random blinks, can anyone help?
    Novelist:
    Scholar:
  • 134 Answers
I think rangerguy42 is saying that it blinks when it's got power & is connected to the pc..? In that case it could be the video card in the pc.. Can you connect the monitor to another pc, just to test it? If it fails to work then, maybe the monitor is faulty. The flashing light it usually a sign that there is no video signal from the pc (when the video cable is connected) Ofcourse it also might be a faulty video cable. I have sometimes seen the pins in the end of the cable damaged Eg bent, or broken. Good Luck.
Posted on May 03, 2008
  • 1,183 Answers
If the power button is blinking after disconnecting it from your computer, and with only the power cord plugged in. Your monitor has gone bad and need to repaired or replaced .Depending upon the manufacturer warranty you have
Thanks
mandeep
When i plug in my Gateway FPD1975W TFT LCD Monitor, the screen stays black and the power button blinks. This goes on for hours without doing anything else. Suggestions?
If you have this connected to a computer and it happens,make sure the fault is not with the graphics card or port first. Test the monitor on another computer or laptop. Test and check the VGA cable.
If this is not the problem (ie the monitor will not work on another computer and another monitor will work on your computer), you are probebly having power capacitor problems and the monitor needs replacing.
This link will explain more
http://en.wikipedia.org/wiki/Capacitor_plague
View sonic monitors were particularly known for this problem
Aug 16, 2011 | Gateway FPD1975W 19" LCD Monitor
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Monitor is black, power line flashing. Help
I assume you mean the power light is flashing? This means that there is aconnection problem or your video card/chip is faulty. Check both of the VGA cable (monitor & PC) are securely connected and there are no bad twists or bends in it, if so replace it. If both ends are secure and cable is o.k. then it is likely that the video card/chip is faulty and needs replacing. Best of luck. Ian.
Mar 29, 2010 | ViewSonic VX924 19" LCD Monitor
Power button on view sonic monitor does not power up the monitor; is it repairable
Please check the power cable if it is not loose. Also check the power switch if it is working. The power switch button for your monitor could have been damaged. But yes, it is replaceable.
Feb 02, 2010 | ViewSonic VP920b 19" LCD Monitor
Need a power supply for View Sonic VX922. Where
Here is a link for your View Sonic power supply:
http://www.shopzilla.com/laptop-power-adapters/viewsonic-power-supply/9177/products
It should have a replacement for you.
Jan 30, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
No power light - no power
Open up the set, check the fuse first then look for bad caps in the power supply, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | ViewSonic VX924 19" LCD Monitor
View sonic flat screen monitor
Problem seemed to be a short in the power cable to the monitor. Replaced the power cable and for the time, the monitor is working correctly.
Jul 07, 2008 | ViewSonic VX924 19" LCD Monitor
17" lcd veiw sonic power blinks
This is a duplicate posting, click on the link below to view the active post: http://www.fixya.com/support/t161845-17_veiwsonic_power_blinking_green
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
