Question about Cyclades TS 3000 (TES0090) Terminal Server
Hi, I have a cyclade console server TS3000. I have connected my unix server to the console server using a normal LAN cable but I am unable to login to the unix server via console. I have tried through cross cable also but no luck. Canyou suggest ome help.
2 Suggested Answers
  • 3 Answers
SOURCE: Console connection from Cyclades TS1000 and Sun
From what I remember you would need a 'rollover cable' that connects the pins to each other in reverse order (e.g. 1 to 8, 2 to 7, 3 to 6, 4 to 5, 5 to 4, 6 to 3, 7 to 2, 8 to 1)
Posted on Feb 04, 2011
How to test TCP ports on ACS48
It sure is. Use a linux distro with NMAP installed, then do nmap-sT -p- -Pn ***.***.***.*-***, replacing the stars with your ip address, and hyphenating the range you wish to scan across.
Aug 03, 2015 | Cyclades Avocent Acs48 Sac 48-port Console...
FROM WHERE CAN I DOWNLOAD WINDOWS XP SP2 LAN DRIVER FOR HP PROLIANT ML110 G6
Hi ppswalia
Since this is a Server, rather than an ordinary Desktop computer, it is not designed to work with normal Windows XP Operating Systems. It is designed to work specifically with Windows, Unix and Linux Server Applications. See here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
There are 2 things you can try.
You can try installing the LAN/Ethernet Drivers for the various Windows Server versions from the above official HP Downloads and Drivers Support Website and see if one of them just happens to coincidentally be compatible with XP SP2.
Assuming there are no further compatibility issues between other Server Motherboard Devices and Win XP SP2 Drivers, you could open the Server case and either bypass any on-board LAN/Ethernet/NIC Port or remove any separate LAN/Ethernet/Network Card installed and install, instead, a pre-confirmed Win XP compatible LAN/Ethernet/NIC Card and then install the drivers for the new card.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 18, 2011 | HP ProLiant ML110 Server
I have a problem, i try to access the Avocent ts100 by hyperterminal in winXp, I used a usb to db9 cable but it didn't access to first page or menu, the hyperterminal configuration is 8n1n, only show...
plz
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. report.gif digg.gifdelicious.giftechnorati.giffacebook.giftwitter.pngstumbleit.gif quote.gif
Jul 13, 2011 | Avocent Cyclades TS100 (TES0061001)
Password recorvery for an Avocent Cyclades ACS 6016 switch
To recover the ACS 6000 console server root password:
1. Connect directly to the console server's CONSOLE port.
2. Turn the console server off, then on again.
3. Press the Spacebar to access the uboot prompt.
4. Type hw_boot single and press Enter.
5. The console server will boot into single-user mode. Type passwd and press Enter.
6. Enter the new password and confirm.
7. Type reboot and let the console server boot normally
Jan 19, 2011 | Computers & Internet
Hi We are unable to scan through our fuji printer and the fault error 016-781 comes whenever we try to do it.kindly help
Set "Sub-net Mask" and "Gateway" of the main processor correctly.
From the destination server, check that you can identify the M/C with "ping."
From a Windows95 or UNIX machine to check that the FTP connection to the destination server is possible.
If the machine is a DC 3535, check that the Ethernet Crossover Cable from the ESS to the Network Controller is connected and is free from damage. Refer to the Network Controller service documentation for repair procedures
Jun 25, 2010 | Xerox WorkCentre M-24 Color Copier
Console connection from Cyclades TS1000 and Sun T3+ using RJ-45 to RJ-45 connector, no response.
Mar 22, 2010 | Cyclades TS 1000 Terminal Server
Unix
Improving UNIX server performance NOTES.INI settings Most NOTES.INI settings that affect IBM® Lotus® Domino® server performance apply to all UNIX® platforms.
NSF_Buffer_Pool_Size_MB Many machines that run UNIX have very large amounts of physical RAM. Use the parameters NSF_Buffer_Pool_Size_MB or PercentSysAvailable Resources to control how much memory Domino is allowed to use. Each Domino instance on a UNIX machine can reference a maximum of 4GB of RAM.
Disk and memory requirements When a UNIX system runs Domino server software, the server must have enough disk space for program and data files and enough memory to handle swapping and the number of processes. You can also change several system parameters to improve server performance.
Disk I/O tuning Maintaining multiple file systems for operating system files, swap space, transaction logs, and data improves overall server performance.
Use RAID 0+1 hardware for the disk drives on which the data files reside. Use multiple smaller disk drives instead of a few large disk drives for Domino data. Domino does not perform simple predictable sequential reads; therefore, disable Read Ahead Cache and enable Write Cache.
Keeping swap space on its own separate striped volumes improves server performance at high loads. The transaction logs should always be on the most reliable and highest performing disk subsystem available to the system hosting the Domino server. Transaction logging must be on its own disk drives for improved server restart time, reliability, and availability. The logged transactions are written to disk as fast serial writes to a sequential file that is of configurable size in 4K blocks.
Console and database logging To improve server performance, limit the amount of information that is logged to the log file (LOG.NSF) and the console.
Feb 21, 2009 | Computers & Internet
Cyclades TS100
no it wont work
Feb 02, 2008 | Computers & Internet
Cyclades TS 3000 (TES0090) Terminal Server Logo
Top Cyclades Computers & Internet Experts
David Payne
David Payne
Are you a Cyclades Computer and Internet Expert? Answer questions, earn points and help others
