Pluged in new LA32R81BDZ LCD Samsung and no plug/play menu ?
    Genius:
  • 3,422 Answers
HI,
Do a hard reset by unpluging the TV for 4 hrs and then plug it back.This will restore the factory default setttings.
Goodluck,
Please don't forget to rate the solution.
Posted on May 03, 2008
    Brigadier General:
  • 6,966 Answers
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, if you are trying to hook it up as a PC monitor, it has to be manually configured depending if the PC is a laptop or desktop.
Alternately, if you feel that something is really wrong with the unit, it may be to your advantage to return to your dealer for a replacement.
Pls post back for any development(s) or even the lack of it and/or additional information.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
I just bought a Samsung BD-H6500 and I was wondering if anyone knew if there was a code for my TV. I have a Haier 42" TFT-LCD, model HL42XD2. If anyone could help I would greatly appreciate it.
Not 100% sure as I don't have these devices, but my tv will find whatever is plugged into the various ports. Thus if a bluray player is pluged into hdmi 1, it will show a disc when I go to my select source menu, it also shows game conttroller for my ps thgat is plugged into hdmi 2. Hope this helps
Dec 24, 2015 | Samsung Televison & Video
No sound from the audio speakers
by audio speakers i assume you mean speakers that you plug INTO the tv, some tv's if you plug in speakers they play instantly but some tv's you might have to go under the menu ON the tv so just bring up menu, click on audio, and it should say some where to swith to external speakers then while with speakers pluged in select external speaker (or whatever your tv might say) and i hope that solves your problem, thank you, jamie.
Dec 15, 2012 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
How to remove Digital noise filter from my samsung lc450 lcd tv
hello, to remove that problem you can use this method;
1. Enter to menu - plug and play - than follow instructions 'til home use and store demo appear.
select home use. or,
2. Push volume button on side of tv until volume bar appear, than push menu button 3-5 second.
good luck.
Mar 27, 2011 | Samsung LE40R74BDX 40 in. LCD Television
I got a second samsung blu-ray player, having liked the first one so much. This new one has been just terrible. Presently neither the sound nor the picture will come on my Proview LCD tv, for some reason...
One thing you might want to try is hooking the player up with the Composite (yellow/white/red) output into the TV. If this gives you a picture, then try a different HDMI cable.
Jan 14, 2011 | Samsung BD-P1500 Blu-Ray Player
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
DVD Player doesn't work???
It may be the yellow RCA plug ,which is the one that controls the picture is bad on either end. Try this. Unplug the red connector from the DVD player and the TV. Plug that red connector into the Yellow jack on the TV and DVD player.If that works it means the yellow wire is bad. Just go to Wal Mart or Radio Shack and buy a new 3way wire system. Check to see how long you want the wires to be as there are different lengths available.
Mar 12, 2010 | Samsung T260HD 26 in. LCD TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Samsung digital retuning for 30 September 2009
Press D.Menu on the remote not Menu! Then select 'Channel' and then select 'Auto Store'/
Sep 30, 2009 | Samsung LE37S71 37 in. HD-Ready LCD TV
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
