Question about Microtest DiscZerver (9270-12)
I have a Zerver that I've had for nine years and never used, I want to start using it now. I've got the manual and assigned it an IP address and I can manage it, but it doesn't seem to be acting right. It's got one CD drive and one hard drive, but the hard drive looks like a CD drive in the list of devices and doesn't show up as a storage device.
  • kholmer Aug 20, 2010
    I don't have much information on it. On the front of the tower it says "JES Hardware Sollutions" and on the inside case it says "DAC Series" and on the controller cover (which is black) it says Zerver. When I log in on the admin page and go to About, it says Version V07.01. If you know where to look to find more info, I'll be glad to do that.
  • kholmer Aug 26, 2010
    did you get my post, with what I can tell about the model?
    President:
  • 1,566 Answers
Hello there,
Can you tell me the exact model of this unit?
Posted on Aug 20, 2010
Connection using ip address for bizhub 350 from desktop
If you want to check the connection from desktop ten follow this.Click on start menu.In run, type cmd and press ENTER.Now in dos mode type ping>space>ip address of machine which you want to check. press enter.If it shows TTL=32 or ttl=64 then it means OK.Your machine is connected with desktop.
Now if you want to put your machine on network and want to assign IP to machine then do these steps1-Connect the network cable to machine.2-Assign an IP to machine.3-To assign the IP, Simply press "Utility/counter" button.4-press "check details" button on LCD panel.5-Now press Admin management.6-Enter password. 123456787-select ADMIN 28-select Network settings.9-Select DHCP.set it to manual instead of auto obtain.10-Now assign the IP in IP address option and after entering correct free ip restart the machine.
Jan 17, 2012 | Minolta bizhub 350 Black and White Copier
Tip
Windows XP: How to release and renew IP addresses
IP addresses can either be assigned manually or automatically. When they are assigned automatically, a DHCP (Dynamic Host Configuration Protocol) server hands them out and determines which computer or other device gets which address. This process usually flows smoothly, but there are times when you may need to release or renew an IP address even when using DHCP.
There are several ways to release and renew IP addresses in Windows XP. Each procedure is described below.
From the system notification tray:
1. Right click on the network connection icon in the system notification tray.
2. Select Repair. Windows will automatically release the current IP address, reset the network connection, and request an IP address from the DHCP server. (The new IP address that gets assigned may be a different one from before, or it may be the same one.)
From the Start menu:
1. Click the Start button.
2. Right click on My Network Places.
3. Select Properties.
4. Right click on the network connection that is currently in use.
5. Select Repair. (If you choose a network connection that is not in use, Repair will be grayed out.)
For either of the above methods, you can release and renew your IP address manually by clicking Disable instead of Repair, and then right-clicking and choosing Enable.
From the command prompt:
2. Click Run.
3. Type "cmd" and press [Enter].
4. At the command line, type "ipconfig /release" and press [Enter].
5. Type "ipconfig /renew" and press [Enter].
6. Type "exit" and press [Enter].
on Feb 02, 2011 | Microsoft Windows XP Home Edition
Tip
Change ip address
How To Change Your IP Address
How do I change my IP? There are MANY methods to change your IP. Some methods will work for you but may not work for someone else and vice versa.
If your IP is static, then you CAN’T change it without contacting your ISP.
If you have a long lease time (explained in this article) on your IP then you won’t be able to change your IP without cloning your MAC address, which I’ll explain later in this article.
It definitely helps if you know how the IP is being assigned to you.
You can read our DHCP definition to get a better understanding.
What is an IP lease time? IP lease time is the amount of time your ISP determines you’ll be assigned a particular IP. Some IP lease times are just a few days and other IP lease times could be set for a year or more. This setting is completely up to your ISP.
One of the easier methods to change your IP is to turn off your modem/router/computer overnight. Then turn it back on the following morning. This method WILL NOT work if your ISP has a long lease time set for your IP.
The following method will ONLY work if your computer is being assigned your external IP and not a router.
How to determine if your computer is being assigned the external IP
If your connection is direct to your computer and your computer gets the public IP and not a router, you can try this:
For Windows 2000, XP, and 2003
1. Click Start
2. Click Run
3. Type in cmd and hit ok (this opens a Command Prompt)
4. Type ipconfig /release and hit enter
5. Click Start, Control Panel, and open Network Connections
6. Find and Right click on the active Local Area Connection and choose Properties
7. Double-click on the Internet Protocol (TCP/IP)
8. Click on Use the following IP address
9. Enter a false IP like 123.123.123.123
10. Press Tab and the Subnet Mask section will populate with default numbers
11. Hit OK twice
12. Right click the active Local Area Connection again and choose Properties
13. Double-click on the Internet Protocol (TCP/IP)
14. Choose Obtain an IP address automatically
15. Hit OK twice
16. Go to What Is My IP to see if you have a new IP address
For Vista
1. Click Start
2. Click All Programs expand the Accessories menu
3. In the Accessories menu, Right Click Command Prompt and choose Run as administrator
5. Click Start, Control Panel, and open Network and Sharing Center. Depending on your view, you may have to click Network and Internet before you see the Network and Sharing Center icon
6. From the Tasks menu on the left, choose Manage Network Connections
7. Find and Right click on the active Local Area Connection and choose Properties (If you’re hit with a UAC prompt, choose Continue)
8. Double-click on Internet Protocol Version 4 (TCP/IPv4)
9. Click on Use the following IP address
10. Enter a false IP like 123.123.123.123
11. Press Tab and the Subnet Mask section will populate with default numbers
12. Hit OK twice
13. Right click the active Local Area Connection again and choose Properties
14. Double-click on Internet Protocol Version 4 (TCP/IPv4)
15. Choose Obtain an IP address automatically
16. Hit OK twice
17. Go to What Is My IP to see if you have a new IP address
Some people have inquired about manually assigning their IP address. This IS possible, but you run a very high risk of your ISP banning you from connecting to the internet. To manually change your IP, follow the steps above for your Operating System. In step 9 or 10, depending on your O/S, enter an IP similar to the one displayed in the command prompt window. For example, if the IP displayed in the command prompt window is 75.1.2.3, change yours to 75.1.2.4. You’ll also need to manually enter the Subnet, Gateway and DNS Server IP addresses as well. If the new IP you give your computer doesn’t work, chances are someone else on the ISP network has already been assigned that IP. You’ll need to move on to the next one and keep trying until you find an open one. However, some ISPs match up your MAC or modem data to the IP that’s been assigned. If those 2 things don’t match up, you won’t be able to connect no matter what. If your router gets the IP and not your computer, you’ll need to http in to your routers interface and manually assign the IP there. It’s pretty much the same method as assigning the IP to your computer. The method that varies is in how you reach your routers interface. You can get the instructions from your manufacturer’s website.
on Jul 02, 2010 | Computers & Internet
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
Ip address in invalid on windows vista
All we need to do is to reset the router for about a minute, if we are still getting invalid IP which is 169.x.x.x then we need to temporarily assign an ip address on the computer.
How to assign IP address:
Windows XP
Step 1: Click Start, then Control Panel.
Step 2: When the Control Panel window opens, double-click Network Connections.
Step 3: Right-click Local Area Connection, then click Properties.
Step 4: When the Local Area Connection Properties window appears, click Internet Protocol (TCP/IP) then Properties.
Step 5: Change the option from Obtain an IP address automatically to Use the following IP address and enter the following:
Make sure the IP Address you'll be assigning the computer has the same first three numbers as the Default Gateway and the last number can be any number between 2 and 99. In this example, our Default Gateway is 192.168.1.1, so the IP address that should be used must start with 192.168.1. In this example, the IP address that we'll assign is 192.168.1.50.
  • IP: "192.168.1.50"
  • Subnet Mask: "255.255.255.0"
  • Default Gateway: "192.168.1.1"
After assign static IP then click OK.
Step 6: If we are not getting any response from the router(like pinging the ip address of the router) then possible product is defective.
Dec 22, 2010 | Computers & Internet
No ip address
Network Card's driver is not installed. Check and install drivers from Device Manager Window.
IP Address can be assigned automatically(through APIPA/DHCP) or Manually.
Automatic:
There is no DHCP server, it takes the Automatic Private IP address(APIPA) or else get it from DHCP server by using "ipconfig" command
Steps: Start>accessories>command prompt>ipconfig /renew
Manually:
Right click on My Network Places> Properties>Right click on Local Area connection>Properties>General Tab>select Internet Protocol(TCP/IP)> Properties>General> select "Use the following IP address> assign IP, Subnet Mask, Gateway and DNS> Press OK Tab.
Dec 10, 2009 | Dell Dimension 3000 PC Desktop
How to set my wrt300n router to use static ip,... i´ve have a problem whit my ps3, and want to use static ip, instead of dhcp(dynamic) should i do it before i do it on my pc and how to do it on the...
You may want to enable the DHCP reservation feature of the router.
What is DHCP Reservation and how do I configure it?
What is DHCP Reservation?
A DHCP reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. Use reservations for the DHCP enabled devices like print and file servers or other application servers which always have the fixed IP address on network.
Step 1: Access the router's web-based setup page. For instructions, click here
Step 2: When the router's web-based setup page appears, click Setup.
Step 3: Click on Basic Setup.
Step 4: Make sure that DHCP Server is Enabled. Then, click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Aug 26, 2009 | Linksys WRT300N Wireless Router
I am using Belkin F5D7632ak4A. My problem is that:
In doing a port forwarding, you actually need to assign a manual address on the computer where you are using the service port for the computer not to change the IP address. If your private address on the network is 192.168.1.XX then you may assign on your computer 192.168.1.2-99 any of the address there. Also you may need to know the DNS you are using on the router which you can find on the status tab of the router.
To assign an IP address, if your computer is wired then right click on the wireless connection and select properties, if it is a wireless computer right click on the wireless connection and select properties.
After you have selected the said properties> look for Internet Protocol TCP/IP then select properties.
Then click on USE THE FOLLOWING IP ADDRESS and USE THE FOLLOWING DNS server as well.
then from there you can put in the set of address you have for ex.
IP address 192.168.1.10
Default gateway 192.168.1.1
DNS
preferred DNS 66.28.87.105
alternate DNS 66.28.87.104
Note: these are just example. after you have done assigning an IP address then you may do the port forwarding again. change the IP address on the port forwarding tab to the IP address you have assigned. Then don't forget to save the settings.
Jul 17, 2009 | Belkin (F5D7230-4) Router (587009)
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
Microtest DiscZerver (9270-12) Logo
Top Microtest Computers & Internet Experts
David Payne
David Payne
Are you a Microtest Computer and Internet Expert? Answer questions, earn points and help others
