Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Have older bobcat zero turn mower, 22 hp kohler command engine, started burning old and filing the spark plug on right side if you are standing behin the engine, had it repaired, 2 new coils, head gasket, and rings. Runs ok but when, i start it up it up it smokes a little bit for a few seconds, it backfires on and off but when i engage the pto it doesent backfire or at least i cant hear it. How do i get rid of the backfire in the engine
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
SOURCE: I have a Kohler Command 17.5 model# CV491S. It
IS YOUR MACHINE A J DEERE?
Posted on Oct 17, 2009
  • 5603 Answers
SOURCE: kohler 19 hp runs then backfires and stalls when heated up
Check that the keyway for the flywheel to the crankshaft hasn't sheared. This is a common problem that throws timing very far off causing backfire and no-starts.
Posted on Nov 02, 2009
SOURCE: kohler k582 runs poorly at operating speed.
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
Posted on Jan 14, 2010
  • 905 Answers
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
Posted on Jun 12, 2010
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Question on craftman riding mower
with the ground wire off the coil and it turns over, you have a bad coil these engines are notorious for this. GOOD LUCK.....
May 23, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
How to remove clutch kohler 23 hp command series?
remove the bolt... if it still doesn't come off the safest way is to put a sacrificial bolt back in and use an air hammer to hit the bolt as the clutch slowly comes off... pb blaster helps a lot
May 18, 2014 | Kohler Engines NEW 23 HP KOHLER ENGINE...
Toro timecutter mower motor upgrade
90% of vertical shaft engines use the same pattern only seen a couple that one hole is off place
Sep 13, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
My Kohler Command 20 HP running fine, shut down, won't restart. How should I troubleshoot this problem?
check for fuel try starting fluid if it fires on that then you have spark if it does not then you have a spark problem and seeing the command engine has two coils check the safety switches on the mower side
Aug 11, 2012 | Garden
Kohler command pro 23 engine model cv23s manuel
that engine uses 2 so if you have no spark from either one check your safety switches unplug the harness going to the engine and try then some have a module check for power in
Jul 02, 2012 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
362 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
