Question about Braun Flex Integral 6550 Electric Shaver
Braun 6550 Sahver: How do I re-assemble the sliding switch mechanism; upon opening, the spring & can plate ejected.
    Problem Solver:
  • 8 Answers
Don't.
Posted on Jun 14, 2011
I need to replace the batteries, but I do not know what part number to purchase. The batteries do not have any part number on them. Braun 6550 shaver
You will find the correct battery type at shaveroutlet.com. See link below. You will need two batteries.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
I suggest that you read the installation tip on the item page as well.
Also, does the green charging indicator light still illuminate when you plug the shaver in to charge? If it no longer lights, don't waste your time with the batteries because your have waited too long to change them and the circuit board is now damaged. Unfortunately, circuit boards for model 6550 are no longer available from Braun
Oct 09, 2010 | Braun Flex Integral 6550 Electric Shaver
Replace rear drum brake pads
for the best help in this you really need to invest $25 in a manual for the vehicle. Here are the basic steps:
-jack up & remove wheel
-slide off drum (emergency brake off)
-remove springs between shoes, parking brake cable, pin thru backing plate with spring and twist cap retainer holding shoes to backing plate, draw or take a picture of each side before you disassemble as they may not be the same exactly on both sides
-check drum thickness & condition (have turned by shop or replace as required)
-rotate adjusting stars in all the way so that new assembly is not spread too wide to fit back in drum
-clean all parts well and re-assemble, use brake cleaner spray only! lubricate friction points of backing plate with high temp lithium grease-very small dab only! (important to double-check all the spring positions and levers and mechanical pieces during re-assembly
-brakes will self adjust to correct position while in reverse and applying pedal you may hear them clicking
Sep 30, 2010 | 2000 Dodge Caravan
I want to replace the braun 6550 with the same shaver, but i cant find anyone who sells them so what is the replacement shaver
shaveroutlet.com may have a PCB that could work in your 6550 model but from what I discovered it is not the same as the one you currently have. It will make the razor function but the LCD will not be available to show battery life. you will have a red and a green light only. If you can live with this than I would suggest contacting shaveroutlet.com. I have the same problem as I have a model 6550 and I have been looking for a replacement PCB ..Printed Circuit Board but have been unable to find one. Call Brian at shaveroutlet.com. I plan on contacting him next week ...Feb 7, 2013 with same problem
Nov 02, 2009 | Braun Flex Integral 6550 Electric Shaver
Lda 511 will not load disc; noisy blapblapblapblap and disc just sits there.
I used an o-ring to fix the problem. Quite easy to disassemble, old belt was removed and similar size o-ring was found at a hardware shop. Put the o-ring on the pulleys and viola. 68 cent fix
Jun 06, 2009 | LG LDA511 DVD Player
Change battry
I don't believe that the cell unit can be changed. It is rechargeable, so if it is not recharging it is probably kaput or your cord needs to be replaced. I looked through all the replacement parts for your shaver and there is no battery available. Here is an address where you can find a place to have it service if you want to or at least speak to someone regarding the shaver.
http://www.braun.com/na/contact/servicepartners/americas.country.html
thank you for using Fix Ya and Good luck to you.
Aug 22, 2008 | Braun Flex Integral 6550 Electric Shaver
TRIMMER STAYS IN OPEN POSITION
I had this problem, and it was due to the breakage of a plastic part.  If you slide the trimmer open you can see a piece of spring wire beyond the end of the word 'trimmer'.  The broken piece should locate the end of this spring; if it fails then the spring no longer forces the trimmer blade fully shut.  As the trimmer was opened and closed I could see that the spring did not stay symmetrically placed.  I could also see one end of the spring inside the mechanism, rubbing on the surface under the slider - but not the other.
To help with the instructions, let me identify some parts: "A" is the sliding part that your thumb pushes to open the trimmer; it carries the word 'trimmer'.  "B" is the hinged part that carries the trimmer blade itself and the word 'washable'.  "C" is the flexible piece of black plastic that connects A to B and on which the central section of the spring pushes.
To fix, first remove the sliding section A: slide the trimmer open and push a thin screwdriver down one edge of the slider.  Prise the lugs that hold A in place, away from their slots. Disconnect the connector C from the blade part B (gently push the lugs outwards, one at a time). Turn over the slider A and you should be able to see that one or both lugs that are intended to keep the ends of the spring in place, have broken.  (They are on a silver moulding fixed to the underside of slider A).  I fixed both ends in place with some two-part epoxy - be careful not to get glue on the other parts!  Allow to dry completely and reassemble.
Aug 20, 2008 | Braun 9595CC Electric Shaver
Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Jul 11, 2008 | Braun Flex Integral 6550 Electric Shaver
Disc wont eject
Hi jamie,
It seems you have opened the top cover of your unit. Now take a dry cotton bud clean the roller which you can find right in front. Please do not use any liquid to clean the same.
Please cast your vote for me if this solve your problem.
ramesh22
May 17, 2008 | Pioneer AVIC-N1 Car DVD Player
Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
Jan 24, 2008 | Braun Syncro 7680 Electric Shaver
Braun Flex Integral 6550 Electric Shaver Logo
325 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
