Question about Craftsman 24 Hp 48" Deck Yard Tractor
My Craftmans lawn tractor the front wheels ars pointing to the outside and not straight. Tried taking the wheels off and moving the sterring wheel, but that didnt work. Its a 48 inch cut mower. It hard to sterr and always wants to go in a one direction. So how do I align the front tires on my mower? Thry are out really bad and just cant mow like that.
Front wheels on husquvana riding mower bow out makes wide turns how to replace front axles ?
I have worked on SO many lawn tractors over the years so I feel comfortable telling you this is probably normal. These aren't precision machines, they're stamped metal decks and mostly plastic machines so there won't be adjustments like your car or a commercial machine might have. There may be one or even one tie rod adjustment for each side, but these are all built with a price point in mind as well as the idea that they are big, cumbersome, not easily controlled, imprecise machines so they're designed to have a high positive camber, (the tops of the wheels angle out farther than the bottoms,) and a LARGE amount of toe-in, (the fronts of the wheels point in at eachother), to assist in maneuvering these cheap hunks of Chinese quality. I really wouldn't worry about it, just get the wheel as centered and straight as possible, anything as far as toe or camber past an inch I'd worry about something being bent MAYBE or jut out of "alignment" but if they, when sitting still, are all approximately less than an inch in either of these directions and close to some sort of symmetry, then that's just normal and these other posters are just making you more worried than you need to be. These tractors support their weight, a close to 90lb engine, your weight, are rear wheel drive, have to move and cut grass simultaneously, AND steer, so the geometry is pretty exadderated to make turning and maneuvering easier. This is why they come with steering wheels
Feb 24, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
The lawn tractor hit a post and now the left front wheel is out of alignment. How can I make it aligned?
the steering tie bar (goes from left to right steering brackets and makes the wheels steer together) should be straight. if it's bent, that is your problem.
Nov 07, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
My front wheels one is straight the other is turned out
Check your front axle the solid piece that goes from one front wheel to the other and attaches the front spindles and wheels. Your probably going to find the solid axle (which also goes underneath the front of the tractor) has been bent allowing that wheel to turn outward.
Feb 05, 2014 | Poulan Garden
What causes ztr front wheel to squeek in motion?
i would take them off and clean off the old grease and apply fresh grease on all moving parts including the the wheel caster section
Jul 14, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
I am working on cub cadet lawn tractor lt 1050. how do i remove and replace the rear axel?
Hello.
SOLUTION ON How to Remove Lawn Tractor Wheels.
Owning a lawn tractor to take care of the grass and yardwork is convenient until the tires need repairing. It is inevitable that sooneror later the tires will go flat and need replacing. You can replace the tiresonce you know how to remove the wheels on your lawn tractor. Unlike automotivewheels which have several lug nuts, the lawn tractor tire requires only theremoval of a retaining ring to release the wheel from the axle.Front Wheels
  • 1 Park the lawn tractor on a level surface. It is better to park the lawn tractor on the driveway or solid shop floor rather than the lawn. Place a floor jack under the front frame and jack the mower up until the front tires are six inches off of the ground.
  • 2 Place jack stands under the frame on each side of the jack and lower the jack until the frame is sitting on the jack stands. If the mower is on the lawn, place a piece of plywood under the jack stands to avoid sinking the jack stands into the lawn.
  • 3 Pop the axle cover off of the center of the wheel. You can pry the cover off with a small flathead screwdriver or grab the cover with a pair of pliers and twist the cover off of the axle.
  • 4 Pull the retaining ring from the axle with a pair of needle nose pliers. Grab the ring from the closed side and pull the ring straight from the side of the axle. If necessary, use a flathead screwdriver to aid in spreading the open part of the ring so the ring will slide off of the axle.
  • 5 Slide the two washers off of the axle and then pull the wheel off of the axle.
Toolsneeded to solve the problem below. Floor jack,Pair of jack stands ,Small flathead screwdriver ,Needle nosepliers ,Vice grips
THEN SOLUTION ON How to REPLACE Lawn Tractor Wheels.
Thanks
Sep 15, 2011 | Garden
Craftsman DLT 3000 Lawn Tractor, Model 917.273821. Two problems for which I'd appreciate any help: Problem 1. The front wheels are not aligned. The left front wheel cants out to the left so much so...
Problem 2 is probably a belt slipping or a pulley loose somewhere.Problem 1 .........is the tie rod adjustable?If the tie rods are adjustable, put steering wheel where it's supposed to be when straight, then adjust tie rods so that each wheel is pointed straight ahead. There should be a lock nut that needs to be loosened, then turn the tie rod end in or out and tighten lock nut. Back to problem 2....if it isn't the belt or pulley, it may not be an easy fix.Sometimes over time, belts stretch and get loose, or a set screw in a pulley can work loose, and cause the pulley to slip on the shaft. If it is hydraulic, it might be low on fluid.. I don't know for sure as I am not a big fan of Craftsman lawn tractors. Good luck
Apr 16, 2011 | Garden
I need to perform a wheel alignment for the wheels are currently pointed outward versus being straight or slightly toed in.
Sounds like something got bent or came loose. Resolve that first.
The alignment is not as important as with cars, meaning straight ahead or toed in, just needs to be straight. Wandering steering is not really an issue on the lawn.
Oct 19, 2010 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Front wheels on craftsman lawn tractor are in two different directions after hitting fence. The one that hit the fence is in a 45 degree angle and the other is straight, how can I realign these.
It depends on if you just bent the tie rod (the rod that goes between the wheels) or if you bent the spindle on the wheel that hit. Look under the front and see if the tie rod is straight. If not, take it off and straightened it. If it is straight, you probably bent the wheel spindle. But also check the axle on the end that hit to see if it is twisted.
Jun 07, 2009 | Craftsman Garden
Craftsman 24 Hp 48" Deck Yard Tractor Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
