Question about Maytag Neptune MDE5500AY Electric Dryer
Lights stay on but can't turn on or off - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 3,053 Answers
Hello, jeanie I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
How can I turn off the rear parking lights
Normally all parking lights are controlled by the light switch. First turn turn on the parking lights and second turn turns on the head lights.
Are you sure it is not your break lights staying on? if this is your break lights - look at break pedal for break light switch staying on or not adjusted correctly. Does your car battery gets drained from your break lights staying on?
Feb 23, 2015 | 2011 Cadillac SRX
GMC Yukon 1999, parking lights stay on when truck turned off, why?
If you pull the 20amp park lamp fuse and the lights stay on, it almost has to be a short inside the headlight switch.
Will the lights go off if you unplug the headlight switch ?
Feb 11, 2014 | GMC Yukon Denali Cars & Trucks
Clicks but won t turn over
Most likely a bad or low battery or bad connection or bad solenoid or starter or combination of any of them. Those lights will mostly stay on till the engine cranks before going off.
Jan 28, 2014 | Hyundai Sonata Cars & Trucks
Tail light stays on when motorcycle is turned off
A long time ago, Honda's had a parking lite, believe it or not. You would turn the key all the way past off and remove it to engage the tail lite. To just turn the bike off, take the key out at off if it comes out ok.
Nov 24, 2013 | 1987 Honda VT 1100 C Shadow
Nissan Altima 2011- e-brake and TCS light stay on
have alternator out put checked with engine running should be 13.5 - 14.5 volts.if alternator not faulty could have bad wheel speed sensor or wheel bearing failing.
Nov 19, 2013 | Nissan Altima Cars & Trucks
Magnavox about 7-10 years old as soon as i turn it on it turns off and stays off
my 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
Sep 18, 2011 | Proton MM2701VT 27" TV
The light insider is still on when i turn off engine?
You may have turned it on ... as in to stay on ... this light normally will stay on for a couple minutes allowing you to get out and away from the car with light ... If you turned it on to stay on ... turn it off.
Oct 30, 2010 | 2003 Lincoln Navigator
Right turn signal stays on will not flash left works.2001 jimmy
its your blinker box.. all major lights run through there
Aug 04, 2009 | 2001 GMC Jimmy
Head lights wont turn off after turnning off car
See if you have fuse under dash or under hood if more fuses in there that is marked DRL , or DRL module. (daytime running light module) may be at fault. Pulling that fuse may isolate problem, otherwise you may have to pull connector off back of light switch to test it.
Jun 06, 2009 | 1995 Dodge Spirit
My turn signals stay on
You have daytime runing lights. When you turn the signal off does it just stay on or does it flash? If it just stays on and you have some light dimming problems, it is more than likely a bad ground on the front signal sockets. This can be repaired by cleaning or replacing the sockets. Another cause of this problem can be traced to bad bulbs,a very easy fix.Good luck Moe
Feb 15, 2009 | 2000 Chevrolet Camaro
Maytag Neptune MDE5500AY Electric Dryer Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
