Question about Lexmark T630 Laser Printer
I have add a new toner cartrige into my printer lexmark T630 but the print is coming blank. morever there is only one side spring on the toner. it seems as the toner is loose. what is the solution
  • LXK Chris
    LXK Chris Aug 20, 2010
    Can you try your old toner? Don't worry if it prints light and faded due to low ink, that would mean that the new toner is bad. If you have already tried it with your old toner and with another new toner yet problem is still the same, the printer may require service. The charge roller, transfer roll or the HVPS may need replacement. Contact Lexmark technical support or your local authorized service provider.
First, replace the toner. If that doesn't fix the issue the print head needs to be changed most likely.
Posted on Aug 26, 2010
Lexmark t630 prints ink on right side of paper
there are typically a few causes of this.
1 - low toner
2 - charge and transfer rollers need to be replaced
3 - high voltage power supply is failing
the first 2 can be checked and fixed very easily
take the toner out and give the toner a shake and replace into the printer.
remove the toner, drop the front door down a couple inches and you will see the charge roller attached to the 2 arms drop down from the top of the printer in the toner bay. if the roller is yellow or orangish it needs to be replaced because the roller should be gray in color. hope this helps!
Feb 08, 2012 | Lexmark T630 Laser Printer
We have a Lexmark T630 and are experencing a black line on the right side of the copy from top to bottom. This started as soon as we replaced the old toner cartridge with a new one. What can be down to...
try testing with the old cartridge if possible. If not i still would replace the cartridge. any time a problem arises after a cartridge replacement it is normally the cartridge
Jan 25, 2011 | Lexmark T630 Laser Printer
Printing blank pages
the printer may be out of toner, replace it or re-fill, if u are sure about toner then driver may be corrupt re-installation of drivers may solve your problem
Nov 15, 2010 | Lexmark T630 Laser Printer
I have installed new drivers and new print cartriges into my Lexmark z23. The test page will print, but when i try to print any other documents, they come out blank??
Good day!Is your new driver compatible with your Lexmark printer?and is your cartridge had no defect?..try to calibrate the cartridge..look to the manual of the printer..
Regards,
mastergani
Mar 21, 2010 | Lexmark Color JetPrinter Z23 InkJet
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
(janddgasrepair@verizon.net)
Don
Apr 07, 2009 | Lexmark T630 Laser Printer
Lexmark T630 Laser Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
