Question about Dishwashers
How do i unattach the front panel of a fisher and paykel two draw dishwasher to access the switches and control circuitry
    President:
  • 2,651 Answers
There are 2 quarter size "buttons" on either side of the drawer(s). pull theese out. htey are pins locking front panel on, after removng pins the fron panel will slide down giving you acesss to innards
Posted on May 03, 2008
Remove the bottom drawer on Dd605 fisher paykel dishwasher
its quite simple there are 2 plastic tabs on either side of the draw on the bottom front corner behind the metal panel on the plastic tub part, simply push on the tab and slide the whole rail back (the plastic tab is the end of the rail it sits on) on both side and the draw will lift out (note it doesn't come out very far as the hoses and wiring will still be attached but will still allow you to access everything). message me if you need pics or more help
Oct 05, 2014 | Fisher and Paykel Dishwashers
How much is service and maintenance of Fisher Paykel bottom draw that does not work
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Jan 03, 2013 | Fisher and Paykel DD605SS Stainless Steel...
Leaks around draws in front of fisher & paykel dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
tr
Jul 23, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher Paykel control panel to far left side has a film on it that chipped off - showing a shinner stainless steal under it. I guess this is a coating of some sort. Dish draws are 4 1/2 yrs old. Mild det...
You can buys the parts that look chipped/ broken and replace them. Panel parts are very easy to replace.
Check out which parts you need from the parts manual and order from the local fisher and paykel distributor.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
The parts that you need are listed from page 6.
Jan 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
NO POWER Fisher Paykel DD603 double drawer
Check to see float switch (located on the bottom of cabinet below bottom draw )hasnt moved or dislodged in transit.(Access by way of back panel-easiest) or removing bottom draw.
Sep 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dish drawer DD601v2
thats tub home sensor switch, mounts to rear right of cabinet and senses drawer closing along with little black box with red switch should also have a little metal actuator( this is what usually breaks off switch), each drawer uses their own. unistall from cabinet and theres an access panel strictly for replacing theses switches
Feb 12, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
