Question about Mitsubishi Televison & Video
2002 Mitsubishi Model VS-60609 Projection TV When cold displays a "bowtie" shaped picture pushed in from top and bottom. All video text and graphics display all 3 colors separated from each other. If left On,video intermittently returns to normal and back to distorted by itself until after approx. 1 hour of flickeringin and out, it returns to normal and remains OK for remainder of use. Symptom then recurs when turned On the following day. Unit is cable connected but other connected TVs show no problem and use of external video inputs such as CD, camera pix, DVD will exhibit same symptom. Any suggestions would be appreciated.
  • 1694 Answers
SOURCE: Samsung DLP HLN5065 intermittent shut off and color scrambled display
bad light engine assembly.......
Posted on Oct 24, 2007
premtech
  • 934 Answers
SOURCE: Service Manual for Mitsubishi 60 inch. Model VS-60609
Jeremy,
I will upload it to Pando now. You will need to have Pando to get it - so go there first and download Pando, it's free..
Bill
Posted on Nov 13, 2008
  • 85 Answers
SOURCE: Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
Posted on May 17, 2009
SOURCE: Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Posted on Sep 19, 2009
SD Tech
  • 14553 Answers
SOURCE: my mitsubishi projection tv, ws55813, was losing
There is a hard reset you can try on this set--it is done with the Mitsubishi remote that came with the set.
Confirm actual model number and I will tell you how to try it. The set will shut off after the reset(not the reset button some of these sets have on the front) and come back on channel 3 in the air band--any labels for inputs will be replaced by original input numbers etc.
No guarantee this will fix your problem but it will return the set to the condition it was when new in the box.
Let me know if you want to try this.
SD TECH
Posted on Oct 25, 2009
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
May 17, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60 in. I get sound but no picture. Just a red, green and blue lines in the middle of screen. Looks like a hour glass shape.
That sounds like a bad vertical circuit. Do you know how to use a meter and solder? If so we can troubleshoot otherwise you will need to call a repairman. A good repairman should run you $300-$500 to repair this. Let me know what you would like to do!
TIm Nolan
Sep 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi (2001 ?) 60 inch projection TV Model VS-60609. DVDs and video games work perfectly but NO tv reception- we have Comcast. I've plugged cable into every possible hole on the TV- no luck. THX!
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
Apr 23, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
