Cant get my laptop to stop roaming and connect to my router
    President:
  • 2,571 Answers
Just had this exact problem on a Advent laptop, sometimes it stops and connects, but most times it tries to connect, resets and starts again. I reinstalled the drivers, uninstalled the wireless card and let the computer reinstall, but this did not help, I think the card is just on its way out.
I had to buy a USB wifi dongle, not the best help i am afraid, just sharing my experience.
Posted on Aug 20, 2010
How to configure roaming in linksys WAP54GPE
Do you mean how to connect to your Linksys wireless router in your home using a wireless connection?
If so then -To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 27, 2012 | Linksys Computers & Internet
Acer aspire 7520 cant connect to LAN ( local only)
Hardwired to modem or router?
Router = check connection to router
(had a router die on me last fall - not AC supply)
IP should be 192.168.1.xx or 192.168.2.xx
(is standard)
Reset Router = reset hole on back - hold for 10 sec
Modem= same directions as router
(most modems work like single port routers)
(do reset of cable modem, I've had that prob too)
Using PPOE connection = check log on info
Took most of my home network apart to find it was the modem causing the problem - should've started there.
Apr 04, 2010 | Acer Aspire 7520-5185 Laptop
Laptop cant connect to router
wireless or wired? Can you ping the IP address on your laptop?
Aug 01, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Internet connection keeps dropping
That may sound like a "roaming tendency" issue, with your laptop wireless card or settings, and/or general radio interference. try checking and tweaking the advanced settings of your wireless card, and maybe check for outside interference between your computer and router. Many cards have roam settings that dictate how often they roam between APs. I too live in an apartment complex, where other neighbors have their own WiFi router and there can be interference, and "intrusion issues" :? if your equipment is not properly set and secured.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
Ubuntu WiFi
Your problem description is too brief, but try the following:
- Check if your wifi is turned on (there should be a button on your laptop)
- Check if your external wifi (usb stick, or whatever you have) is installed properly
- Check your IP address, if its in the same IP-range as your router's
- Check your gateway IP
- If you have access reset your router
It should work so far by now, if not:
- Switch to roaming mode
- Try to connect your laptop through an ethernet cable, if it works find out those settings (IP, gateway etc.) and use them with your wifi thing.
If this doesn't help, there is either a problem with your router or the network must be secured.
Nov 02, 2008 | Canonical Ltd. Ubuntu
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cant run 2 laptops from router
check your dhcp scope in the router, make sure that you have 4 or 5 dhcp leased ip to allow maximum of 4 connections. thanks
Oct 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless router keeps loosing connection
go to wireless device and re-configure it
Jun 14, 2008 | Dell Wireless 2350 Router
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
