Question about Ovens
The bottom light does not light up. The bulb burnt out so I replaced the bulb and now nothing. The display shows Light Hi, Light Low and light Off but the bulb does not light up.
    Sergeant:
    Champion:
  • 311 Answers
The control board has failed.
Posted on Aug 20, 2010
Testimonial: "Thanks. not what I wanted to hear, but still helpful"
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
My oven light is replaced with a new one but still not lighting up
Bulb socket must have a problem. The bottom contact is not touching the bulb. You may need to replace the socket if you can't bend the bottom contact back into place.
Feb 18, 2015 | Neff Ovens
The light of the easy bake won't turn on
Take a working lamp and plug it in to the electric outlet you plugged the oven into and make sure it's ok.
There is nothing in the instructions if a light-bulb is used, it does say heating element but there is nothing on how to change anything.
The instructions don't tell you anything but how to use.
If you can return it, do it as fast as you can. If you can't you are going to have to call Hasbro.
1-800-327-8264
So sorry I couldn't be more help.
If you don't get somebody that owns this to respond just post it again, if you don't want to return it and want someone who has it to respond.
Because the door does not open, has no door, the only place I would think of is the bottom might have a access panel.
Have someone see if it has a panel that can be opened and look inside for a bulb and check to see what size and wattage, then make sure you use a appliance oven bulb.
Apr 02, 2013 | Ovens
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Oven burner doesn't light. Igniter doesn't light. Boiler burner does light and Igniter does light
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Mar 01, 2010 | Maytag Ovens
Whirlpool gas range model # GS475LEMS0; Oven light won't come on
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. 250
Nov 16, 2009 | Ovens
Burnt out light bulb in microwave
well it is an absolute nightmare changing the light bulb in the microwave. you have to basically remove the microwave from the rest of the appliance to get to the light after remove panels and other parts. if you intend on doing this take your time. best solution is to have a repair do it that way if it doesn't work he/she is liable not you. best of luck
Jun 20, 2008 | KitchenAid KEMC308 Electric Double Oven
Ovens Logo
146 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
