Problem in watching hidden files.
Hi mate
I have problem in opening the hidden files. when i select to show the hidden file it automatically select the option "do not show hidden files" after some time.
regards.
  • Anonymous May 05, 2008
    in my computer icon c drive d drive are not opening. It given to open in which program
  • 3 Answers
I had earlier experienced the same problem of when you double click the Drives....the response is an open with dialog bo..If they were earlier opening when you doble clicked .Its most probable that a virus has infected your machine..Try to clean it wih a stong and updated antivirus..Also if you have to access the drives try to right click on them and click explore on the pop-up menu..
Try opening them in windows explorer..for option two
Posted on May 05, 2008
My Laptop recognizes the "My Book 300GB External Hard Drive" but when I go to my computer and click on it none of the files show up. The Icon in the "My Computer Page" Says they are still there. How d
Please check that you do not have any hidden folders from Control Panel, Appearance and Personalization, Folder Options.
If "Show hidden files" option is selected, open the cmd and use the attrib command. You should write
attrib -h -r -s /s /d z:\*.* (where "z" is the letter of your drive).
http://windows.microsoft.com/en-us/windows/show-hidden-files#show-hidden-files=windows-7 - Show hidden files
http://en.kioskea.net/forum/affich-649922-attrib-command - check this similar topic.
Hope this helps
Oct 07, 2014 | Computers & Internet
Tip
How to check whether a virus has effected a PC
Most common type of virus disable the windows capability to show hidden files. To check whether the computer does not have virus , goto My Computer > Tools (Tab) > Folder Options > View >
Select "Show Hidden Files and Folders"
Click apply and ok
Again repeat the same procedure and check whether the selected "Show hidden files and folders" is still active or its been return to the "Don't show hidden files and folders".
If its still active then it means virus has not effected the system of at least you could delete the hidden virus files.
If it automatically return to the "Don't show...", virus has effected you system. Then go for a good anti-virus software.
on Dec 07, 2009 | Computers & Internet
My seagate 1Tb is actin strange.. when i try to explore it, it shows it's empty but when i check it through properties.. i have all my files hidden to it.. all my files got invisible.. please help..
Win 7 - open the drive on the computer, click the "organize" drop down menu on the left - go to "folder and search options" - select the second tab (view) - select "show hidden files, folder, and drives" - Hit apply then ok - all of your files should be visible now - select all files by hitting "CTRl" + "A" - right click on one of the files and select properties - uncheck hidden - when/if another window opens select the best option for you - now all your folders should be visible again - you can repeat the first few steps to make your hidden files invisible again if you wish.
Oct 15, 2013 | Computers & Internet
I have a WD my book drive. When I try to see the files on the drive they are Not there, But when I click the properties the drive shows half the drive space is used. how do I get the files to show be...
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 04, 2011 | Western Digital My Book Essential Edition...
Hello I cannot see or open the files
The file which you want to open or see must be hidden. To show all hidden files do the following: Type control.exe in the Run box this will open control panel. Now double click on Floder Option and click on view tab. Now under Hidden Files and Folders select Show hidden files and folders. Now click on apply and then ok. So steps will show all the hidden files and folders, now you must be able to see the file.
Aug 25, 2010 | Computers & Internet
How can i view hidden files in windows xp?
Kindly follow the following steps to view your hidden files in your PC...
1. Double click & Open the 'Windows Explorer / My Computer'
2. From the file menu bar select 'Tools'
3. Select 'Folder Options'
4. Select the 'View' Tab on the Option Window
5. In that tab you will find 'Hidden Files & Folders' with a folder icon
6. Select the 'Show Hidden Files and Folders' by selecting the radio button.
7. Then select 'Apply'
Now you will be able to view the hidden files & folders in your system. I have enclosed the screen shots for your better reference.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
How can i view my hidden files ?
Show hidden files
Follow these steps to display hidden files and folders.
  1. Click to open Folder Options.
  2. Click the View tab.
  3. Under Advanced settings, click Show hidden files and folders, and then click OK.
Aug 23, 2009 | Microsoft Windows XP Professional With...
Could not select "show hidden files & folders" in folders option
go to system registry.......click start then run and type regedit then find this key HKEY_ LOCAL_MACHINE software microsoft windows current version explorer advanced folder hidden showall
in your right pane show it DWORD key of CheckedValue delete it.....and create new DWORD key and give the name CheckedValue and enter 1 into value data.......
restart your pc..........
good luck.........
The best earn money site..plz signup free
http://bux.to/?r=jiteshright
(Join now and receive a $0.05 Sign-up Bonus)........click on it........
Jul 30, 2008 | Microsoft Windows XP Professional for PC
Hiddin file i can`t see
well, try to search your file.
In more advanced options select show hidden files and folders.
Jul 29, 2008 | Computers & Internet
Show hidden files
you should be able to click to open folder options, click the
"view" tab, and under advnced settings, click show hiden files
and then click OK. Don't do this on a web browser--you have to
do it from a Microsoft program.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
