Question about Toshiba E-Studio 160 All-In-One Laser Printer
Paper Misfeed error occur when ever Toshiba E-studio 160 Machine started. the code will come out E03. I was already clear all jam papers and also fully clean machine by air pressure by blower please help me.
4 Suggested Answers
ijs1121
SOURCE: paper jam
as komguy says above, the best way to fix this error is to feed paper through the printer manually. i found that a full sized sheet of cart stock did the trick. feed it from the rear paper tray and manually turn the gears to the far left of the printer.
Posted on Jun 20, 2009
  • 19 Answers
SOURCE: Printer says paper jam when there is none
The printer may have an optical paper reader near the print head.
If you can, remove any plastic covers and blow out the head area with compressed air.
The optical reader may be located somewhere else also.
They get covered with paper dust and think its a paper jam.
Blow out all areas of printer.
Posted on Dec 22, 2009
andi_bunkka
  • 102 Answers
SOURCE: My Toshiba E-Studio 650 is displaying a paper jam in the copier. I have removed all paper jam and I have replaced sensor. What am I missing?
There are other sensors to check or verify that there is continuity in the wires of the sensor that you've removed
good luck
Posted on Apr 25, 2012
How do I fix the error code E03 on my toshiba e studio 163 printer?
Power-ON jam: The paper is remaining on the
paper transport path when power is turned ON.
Nov 14, 2017 | Toshiba Office Equipment & Supplies
E03 code toshiba photocopier
Mar 15, 2016 | Toshiba e-Studio 207 Copier
E03 error in toshiba e studio 207
Power-ON jam:
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
Toshiba e studio 212 copier. Gives error code e03. Paper has been cleared and no particle inside, all sensor in place. Still gives error e03. What to do?
Search carefully onto the fuser cover for the actuator for exit sensor.
There is a spring that moves the actuator into normal position when the paper has passed. If it seems the spring is out from the actuator it will think there is still a paper jam. The best bet would be to call a service company to come out and make repairs if you are unable to get this spring back into place. After resetting the spring into the correct location, restart the machine and see if the problem continues. If it works and then goes into error mode again, it is likely this spring and or senor will need to be replaced.
Good luck.
May 13, 2014 | Office Equipment & Supplies
Paper misfeed error code E030
Apr 09, 2014 | Toshiba E Studio 2330C
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
good luck
Apr 24, 2012 | Toshiba E-STUDIO 650 Copier
My Toshiba E-studio 650 keeps E03 which means paper jam how can I fix this?
Probably moved some sensor caused by the paper jam, the sensor looks out of place or dirty and also check the continuity of the cables.
Apr 24, 2012 | Office Equipment & Supplies
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Toshiba E-Studio 160 All-In-One Laser Printer Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
