Question about Briggs & Stratton Garden
I need a manual for yard machine lawn mower model 11A504D000. I need to do some repairs.
SOURCE: Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Posted on Jun 01, 2009
rburroak
  • 14 Answers
SOURCE: "how do i change the primer bulb on my yard machine lawn mower"
You should be able to remove the old one with a screw driver or needle nose pliers. The new one should have a new gasket with it.
Posted on Jun 19, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
  • 3 Answers
SOURCE: Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Posted on Apr 02, 2010
Testimonial: "Thanks very useful information.....Many Thanks"
kel1guy2002
  • 3740 Answers
SOURCE: yard machine lawn mower won't start
Several questions here...
1. Is the oil serviced to the full mark?
The oil level sensor can cause a no spark condition because it grounds the ignition.
2. Is there spark at the spark plug? You can remove the spark plug and test for spark but if the plug is internally grounded it will show spark when removed but if it is installed it can still be defective. (Spark Plugs are cheap replace it)
3. Is the handle safety cable loose even when depressed? A bad safety cable or an improper cable adjustment can also cause a lack of spark.
4. Do you note gas on the spark plug or is it very dry? If the spark plug is dry try adding a splash of gas into the cylinder via the spark plug hole and see if you get a temporary / momentary start. If you do then you have either a fuel supply or carb problem.
Make sure the fuel selector is in the ON position.
5. If you suspect a fuel problem disconnect the tank feed line to the carb and see if there is fuel flow from the tank, No fuel flow no start.... then problem in the gas tank or supply line.
I will post this as a solution but will watch for any responses and continue to assist you if needed.
Thanks for using FixYa.
Kelly
Posted on Jun 17, 2010
Yard machine riding lawn mower won't crank over
You might want to refer to this Yard Machine Riding Mower Manual for troubleshooting techniques.
Feb 02, 2013 | Garden
Repair manual
model number 13A0695G092
What you provided is the model number. Please also provide the serial number as well so we can know. Thank you,
MR-PNG
May 24, 2012 | Yard Machines Garden
Need an engine manual not supplied with new mower just purchased at Home Depot. Yard Machine sent an operators manual but no engine manual. Unit has a B&S ABSXS-1581VG engine, 158cc, SN 10 0518 54...
GET ON YOUR COMPUTER PUNCH IN MAKE MODEL AND YEAR OF YOUR LAWN MOWER THE SITE WILL COME UP THEN PUNCH IN A REQUEST FOR YOUR MOTOR AND IT SHOULD GIVE YOU A MANUAL YOU CAN DOWNLOAD ON YOUR COMPUTER
Sep 29, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I NEED TO LOCATE A DECK FOR A 46" YARD MACHINE
You probably have in your area a number of small engine repair shops. You will have to get on the phone and start calling around for a used mower deck. They usually have many old mowers in there yards. If you decide you only want new it could be very costly. GOOD LUCK.
Jun 30, 2011 | Yard Machines 155 Torque Briggs Stratton...
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Cant find a wiring diagram for my 17hp briggs and stratton 42inch cut yard machine lawn tractor it will not turn over with key i just got it cheap but have noticed three wires that are cut but dont seam to...
Try going to: http://www.manualsonline.com/
This download is free.
Most owners manuals have a wiring schematic diagram page in them. You will need the model # on this site to check for an online operators/users manual. Most REPAIR manuals on the net are either book or CD and are not free.
Aug 29, 2010 | Yard Machines 155 Torque Briggs Stratton...
Repair manual Model No. 243-143A401
Go to www.mtdproducts.com. Put in your model and serial number. It will come up with a parts list and diagrams. It is very important you have both numbers when visiting this site.
Dec 28, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
To whoever i have a 46'' 18hp riding lawn mower
You can find it here... http://manuals.mtdproducts.com/mtd/public/list.jsp You will have to enter the model and serial number that should be under the seat.
Jun 13, 2009 | Garden
Garden Logo
49 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
