My ikasu dm069414 wireless printer prints a 4 instead of u
I'm using a wireless canon pixma mx350 but am unable to print web pages, in particular from a HSBC site. As soon as I click print, the printer disappears!
1.Try doing Ctrl+S and saving the webpage to your computer first. Then open the saved webpage and try printing from there. 2. If that doesn't work, try right clicking in the portion of the page you wish to print, and doing "Print This Frame". 3. If that is not an option, try using Ctrl+P instead of clicking on the print button. This should bring up the print dialog. 4. Otherwise, try using Ctrl+A to select everything, Ctrl+C to copy it, open a new Word document and use Ctrl+V to paste it. Then try printing the Word document.
Good luck! And PLEASE leave me positive feedback!
Jul 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
How to connect lexmark p4350 to laptop with radio link
The Lexmark P4350 printer is not capable of wireless connection. Try to use a wireless print server instead for wireless network connection.
Jul 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
Is a canon Pixma MP160 a wireless printer? I would like to make my printer which I now use a usb cord and make the printer a wireless connection instead, and I cannot find in the manual if it is wireless...
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Jan 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Had printer working with desktop, purchased wiless and cannot get printer to communicate.
Well it's better if you tell me which operating system you are using....?
anyway please follow the below steps to communicate your printer to the desktop  -
1. Check if your printer is network ready. Many newer models are designed to work on networks. Examine the documentation to see if your printer supports Wi-Fi (802.11x) or Bluetooth.
2. Add network support to your printer. If your printer is not already wireless you can connect it to a wireless router using the RJ-45 Jack (it resembles a large telephone jack). You can also buy an expansion card that will add a jack or buy an external print server that will connect to the USB or parallel port.
3. Connect your printer to the network. If your printer is not wired, you’ll have to connect it directly to your wireless router. Connect a networking cable from the RJ-45 Jack on the printer (or adapter) to the router. Plug it into any jack except the UPLINK. The printer should automatically connect to the network when turned on.
4. Install printer drivers on all computers. Using the disc that came with the printer or drivers downloaded from the manufacturer, install the printer’s drivers onto each computer on the network.
5. Print. You should be able to access the printer just like any other wireless device. Select the printer from the Print menu when you print.
Share Your Printer in Windows
1. Install the printer. Set up the printer as normal on a machine that is already connected to the wireless network. Connect all necessary cables and install all necessary drivers.
2. Open the printers and faxes folder. Click "Start," then "Control Panel," then "Printers and Other Hardware" and then "Printers and Faxes."
3. Share your printer. Find the icon for the printer you just installed. Click the icon once and then select SHARE THIS PRINTER in the tasks pane on the left. Now, right click the icon, select properties and go to the SHARING tab. Click "Share Name," and then click "Okay."
4. Connect to the printer. On the other computers within the network, open the control panel and click "Printers and Other Hardware." Select "Add a Printer."
5. Select "Printer Connection." When prompted, select this option instead of the local printer. Find and select the printer you just installed and select it.
6. Print as normal. Next time you print a page, send it to your networked printer.
Good Luck!!
Thanks
Dec 07, 2009 | Lexmark X3650 Printer
Trying to connect printer to computer wireless
  1. Step 1 Check if your printer is network ready. Many newer models are designed to work on networks. Examine the documentation to see if your printer supports Wi-Fi (802.11x) or Bluetooth.
  2. Step 2 Add network support to your printer. If your printer is not already wireless you can connect it to a wireless routermag-glass_10x10.gif using the RJ-45 Jack (it resembles a large telephone jack). You can also buy an expansion card that will add a jack or buy an external print server that will connect to the USB or parallel port.
  3. Step 3 Connect your printer to the network. If your printer is not wired, you’ll have to connect it directly to your wireless router. Connect a networking cable from the RJ-45 Jack on the printer (or adapter) to the router. Plug it into any jack except the UPLINK. The printer should automatically connect to the network when turned on.
  4. Step 4 Install printer drivers on all computers. Using the disc that came with the printer or drivers downloaded from the manufacturer, install the printer’s drivers onto each computer on the network.
  5. Step 5 Print. You should be able to access the printer just like any other wireless device. Select the printer from the Print menu when you print.
  6. Share Your Printer in Windows
  7. Step 1 Install the printer. Set up the printer as normal on a machine that is already connected to the wireless network. Connect all necessary cables and install all necessary drivers.
  8. Step 2 Open the printers and faxes folder. Click "Start," then "Control Panel," then "Printers and Other Hardware" and then "Printers and Faxes."
  9. Step 3 Share your printer. Find the icon for the printer you just installed. Click the icon once and then select SHARE THIS PRINTER in the tasks pane on the left. Now, right click the icon, select properties and go to the SHARING tab. Click "Share Name," and then click "Okay."
  10. Step 4 Connect to the printer. On the other computers within the network, open the control panel and click "Printers and Other Hardware." Select "Add a Printer."
  11. Step 5 Select "Printer Connection." When prompted, select this option instead of the local printer. Find and select the printer you just installed and select it.
  12. Step 6 Print as normal. Next time you print a page, send it to your networked printer.
Hope this Help.
Cheers!!!!
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
Wireless
It is true the wireless upgrade printing kit will not be compatible with C1315 All-In-One Printer.
And also instead of going for a wireless upgrade printing kit you can buy a Wireless All-In-One printer for the same price and a new printer with a Year warranty as well, Check this link Bellow:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/Q8401A%2523ABA
Good Luck
Sep 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Wireless set-up for my Kodak Photo printers, "HELP!!"
u have to configer router for the wireless connaction to connact your all your laptop in wifizone u have to carate wireless lan u have here is link to setup printer in network
Jul 17, 2008 | Kodak (856-3678) Print Server
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Open Questions:
Computers & Internet Logo
David Payne
David Payne
