Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Freezer hums and whirls as though the motor is engaging and then disenganging
I just recently noticed that our GE Profile Side-By-Side is making a whirling/ humming sounds as though the motor is engaging and then disengaging. When I open the freezer door you really hear it, but it is noticable even when the door is closed. Its not the normal kicking on and off cycling to keep the refrigerator/ freezer cool.
Any ideas what it could be or if there's anything I can do other than contact an appliance repair person? I would at least like to narrow down or locate the problem.
We are having the same problem at the moment. I have heard that it is something to do with the control panel. Maybe you should contact your fridges manufacturer and ask about it. I may be incorrect here because I am not too sure myself. It may be something to do with the twin cooling. I would phone up your manufacturer if I was you. we havent phoned anyone yet. However, our fridge is a SAMSUNG. I do hope this helped!
Posted on May 03, 2008
The fan inside the freezer makes a loud humming noise ,but not all the time.
The bushings in the fan motor are gummed up. The fan motor can be removed and cleaned and lubed if you are a fix it person, but changing the fan is much easier
Mar 21, 2010 | GE Profile PSW26P Stainless Steel Side by...
The compressor motor on our GE Profile side by side has been making a loud banging sound when it shuts off. Now, it doesn't shut off at all. I notice some ice formed in the back of the freezer.
two seperate issues,the springs within the compressor housing that support the piston have broken,can only be resolved by replacing compressor....in regards to the ice build up,you have a defrost problem.defrost issues can usually be resolved for about 120-160.00 through a qualified servicer
Mar 06, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE - SIDE BY SIDE MODEL TFX25JR - Continous HUM
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Humming and frosting in freezer
Your defrost has stopped. Either the defrost heater, bi-metal or the control board has failed.
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
Layer of frost on the bottom surface of ice maker
during periods of high humidity and or high use, it is not unusual to notice frost on surfaces in the freezer. the ICM is susceptible due to it being metal and having warm(compared to freezer temp) water in it. make sure the doors ar closed tight and nothing is stuck in the gasket area.
J
Jun 13, 2008 | GE Profile PSI23NCR Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
