Scientific Explorer My First Chemistry Kit Logo
Posted on Aug 20, 2010
Difference between covalent and ionic compound
DubbleA
Level 1:
Scholar:
  • Contributor 32 Answers
  • Posted on Jan 10, 2011
DubbleA
Contributor
Level 1:
Scholar:
Answers
32
Questions
Helped
16598
Points
46
In general, the most common covalent compounds do not contain a metal as one of its constituent elements. So, with few exceptions to be mentioned momentarily, if you do not see a metal atom in a formula for a compound, it is probably the formula for a covalent compound. (An exception to this is butyl lithium, BuLi of the class of organometallic compounds, which have very little ionic character, even though they contain an ion.)
Most Ionic compounds contain at least one positively charged metal atom, such as NaCl. The metal is sodium as its positively charged ion, Na+. (There are exceptions to this rule. For example, NH4Cl, ammonium chloride, is an ionic compound, containing the ions, NH4+ and Cl-.)
Suggestion: Memorize the common elements and what ions they can form. Study atomic structure and quantum mechanics theory, the aufbau theory, the major trends of the periodic theory, which will give you a systematic way to estimate or predict the ions and the charges of many of the elements. Knowing the trends and patterns in the periodic table will allow you to easily recognize which elements are metals and which are nonmetals. This knowledge, combined with the rules given above in paragraphs one and two, will empower you to distinguish between covalent and ionic compounds, because you will be able to recognize when a compound contains metals or only nonmetals.
1helpful
What are some examples of metallic bonds
Metallic Bonding Examples
Like NaCl is an example for ionic bonding, various metals like iron (Fe), lithium (Li), potassium (K), gold (Au), silver (Ag) are all examples of metallic bonding. Even the alloys of metals are the perfect example of such bonds. Brass, an alloy of copper and zinc, Terfenol-D (a magnetostrictive alloy) and various chemical elements are some other examples of compounds that consist of metallic bonds. Most of the metals have only one or two valence electrons and their ionization energies are very low, that is, the valence electrons are not very tightly bound to the atom and they are easily mobile from one to the other atom. This ease with which mobile electrons move in a crystal lattice determines the bond, that means, ionic, covalent or metallic. The properties exhibited by metals are due as mentioned in the above paragraphs. For instance, consider gallium, molten gallium is a very non volatile liquid in its molten form and it is due to the strong metallic bonding in gallium.
Metallic bonding forms one of the various forms of chemical bonds studied in chemistry. This was some brief information on this form of bonding that is the main reason for various physical properties of metals.
Read more at Buzzle: http://www.buzzle.com/articles/metallic-bonding.html
My dad has an ionic breeze that quit working. A repair shop told him it was the power supply. Where can you buy a replacement part?
Hi.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
My ionic breeze GP air purifier will not turn on. I turned it off to clean the blades and when I reinserted and tried to turn it on nothing happens.
Hi.
The filter will probably needs replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. New model use a completely different technology. Parts are also not distributed anymore.
Regards.
Ginko.
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
Regards.
Ginko.
4helpful
3answers
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Is isobutane covalent or ionic
Like methane, isobutane has a covalent bond.
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
Regards.
Ginko.
Ionic breeze stopped working won't turn on was very dusty, cleaned it wont light up
Hi.
When this happens, usually the filter must be replaced.
Regards.
Ginko.
Ionic breeze gp just stopped working
Hi.
I don't know if you are still trying to repair the air purifier.
About your Ionic breeze purifier, I wanted to report that they are not being manufactured anymore because of heath concerns. New model built from 2008 use a completely different technology. Parts are also not distributed anymore, and the new Sharper Image does not provide any support for the old model.
Regards.
Ginko.
Top Scientific Explorer Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Scientific Explorer Toy Expert? Answer questions, earn points and help others
