Question about LG 42LG50 42 in. LCD HDTV
My 42 inch LG tv, has an rather loud humming/buzzing noise when the Television is switched on, the noise is quite constant and is a constant pain
  • 3 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
  • 63 Answers
SOURCE: LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Posted on Aug 19, 2009
  • 325 Answers
SOURCE: just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Posted on Sep 28, 2009
dave1645
  • 834 Answers
SOURCE: Buzzing noise from 42 inch Samsung Plasma TV
this is a comon occurance in theis model it is caused be loose laminants in the switching tranformer sometimes it can be fixed by covering it with clear GE silcone
Posted on Dec 01, 2009
  • 8457 Answers
SOURCE: LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
Posted on Feb 08, 2010
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
It has a loud buzzing noise how do I fix that problem?
It appears that your connections are not correct. Please switch off the TV. Disconnect all the cable. Wait for some time. Reconnect cables one by making sure you strictly follow the color code i.e. that red pin cable must go in the red socket. After all the cables are connected switch on the TV. Loud buzzing noise is due to wrong connection of cables especially the Earthing/Neutral
Apr 07, 2011 | LG 42LC2D 42 in. LCD HDTV
We have a constant buzzing/whining noise when the TV is on.
Is it a whuring or buzzing sound? When color wheels go bad they can make a lot of mechanical nose, cooling fans can do the same but they do not spin as fast as a color wheel does
Jul 08, 2010 | Samsung HCM4215W 42" Rear Projection...
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Feb 08, 2010 | LG 42LH30 42 in. LCD TV
Aug 19, 2009 | Vizio L37 Television
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG LC55 humming/buzzing
Have you tried adjusting the contrast? , have a similar problem with a 42'' lcd and it appears to be related to the contrast setting .If is set my contrast below 90% the buzzing sound stops.
This buzzing sound seems to be a common problem with LG TV's
Nov 24, 2007 | LG 42PC5D Television
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
LG 42LG50 42 in. LCD HDTV Logo
144 people viewed this question
Computer Repairing
Computer Repairing
