Question about Garden
Need fuel to oil ratio for husqvarna 223L trimmer
  • 490 Answers
Here is the scoop copied from the Husky site:
Two-stroke oil
• For best results and performance use HUSQVARNA twostroke
engine oil, which is specially formulated for our aircooled
two-stroke engines.
• Never use two-stroke oil intended for water-cooled
engines, sometimes referred to as outboard oil (rated
TCW).
• Never use oil intended for four-stroke engines.
• A poor oil quality and/or too high oil/fuel ratio may
jeopardise function and decrease the life time of catalytic
converters.
• Mixing ratio
1:50 (2%) with HUSQVARNA two-stroke oil.
Hope this is helpful, let me know if it's not and I'll come at it some other way:)
Posted on Aug 20, 2010
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded.
second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
May 30, 2013 | Husqvarna 223L
Husqvarna 326 ls e-tech trimmer
Yes the 326LS is an e-tech strimmer, Fuel to oil mix ratio is 50:1
50 parts fuel to 1 part oil.
Apr 09, 2013 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.
Lock throttle trigger on,
Start on full choke till it fires,
Switch to half choke and it should fire up on high revs,
Blip the throttle and it should turn to tick over.
If it still keeps cutting out it could point to a carb or fuel takn issue.
Aug 04, 2012 | Husqvarna 223L
How much oil do I use per 1gallon of gas for a Husqvarna 223L weed eater?
for a 40/1 mixture use 3 ounces of oil ( 2 stroke) to a gallon of gas for a 50/1 ( which is what I recommend ) its 2.5 ounces to each gallon of gas, if you find that the machine is smoking a little too much,, back up on the oil just a hair,, but I don't think you'll need to
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
What is the oil to gas ratio for the husqvarna 125l weed eater
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Apr 10, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 223l trimmer shuts off
See if air cleaner is plugged or needs changed or cleaned
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
2,091 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
