Question about GE Monogram ZDI15C Automatic Icemaker
I have a Ge Monogram ice maker ZDI15CBB. It is almost 5 years old. It has become very noisy and when you open the door it smells hot. Have cleaned the coils and machine...any suggestions to what is going on. Is 5 years about the life span for one of these machines?
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
  • 1214 Answers
SOURCE: GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Posted on Jan 24, 2009
peyton32034
  • 410 Answers
SOURCE: My GE Monogram Ice Maker keeping turning its self
the rate the light flashes is a code for trouble shooting the electronics on the unit ( such as bad coil sensor, bad bin sensor or shorted grid cutter) if you will look behind the front grille you should find a tech sheet that will tell you what the flasing means and tell you what components to replace. BTW the most common failure is the cutter grid and bin sensor. the sensor is the white rod on the right hand wall inside the unit. besure it is plugged in. Let me know if I can help you futher. thanks Peyton
Posted on Mar 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
SOURCE: Ge monogram ice maker makes loud churning noise
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Posted on Jun 17, 2009
Where can I find a replacement pump motor for my GE Monogram ZDI15CBB Ice Maker? It's a Jakel J238-062-6510 motor.
Which pump are you looking for? Drain or recirculating pump (WR57X10028) now GE didn't produce this unit so you can find this part cheaper from Whirlpool part number 2217220 for half the price. As for the drain pump 1901A is a complete kit for an ice machine for the external drain system. I hope this helps. Good Luck
Mar 28, 2016 | GE Refrigerators
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
My ice maker over fills. The fill switch must not be working? You open the door and ice spills out.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 25, 2010 | GE Monogram ZDI15C Automatic Icemaker
How to thaw ge monogram frozen ice maker
switch it off,open doors,and let it defrost naturally,you could leave a bowl or two of hot water in the bottom,but do not try to speed up the defrost precess(spraying anti freeze causes odour problems later).
then make sure all drains/vents are clean.
Mar 31, 2010 | Refrigerators
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE ice maker is getting hot
You need to remove the ice maker the function that heats the lower element should last only a few seconds so I believe the ice maker will need to be rebuilt or replaced. Sea Breeze
Jul 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice Maker Quit Working
Replace the whole i/m - it is bad. Takes 5 minutes to do. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | GE Monogram ZISS420DRSS Stainless Steel
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
168 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
