Question about Sony Playstation 3 (PS3) Console
My hard drive has corruted files my games want load but it will play dvds
  • 277 Answers
You can also try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Take care.
Posted on Aug 20, 2010
Console locks up after a few minutes of game play. Does not respond to remote. If eject button on console is pushed, console will unlock, then will continue and 15-30 seconds later, disc will eject, but...
dlmorgan195
If you are able to play DVDs with out through then most likely the system is not over heating. So you may have corrrupted data on the hard drive. I would recommend that you backup you save files and go through the steps below to format the hard drive. If you still have trouble they you do actually have a hard ware problem with the system.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 13, 2010 | Sony Playstation 3 (PS3) Console
How do I down load to an external drive and not the main computer
First Solution:-
1. If you have copied a particular game's folder to the external drive, go to Start menu > Programs.
2. Right click on the file name of the game.
3. Click on "Properties"
4. Go to "shortcut" page and change the "Target" path directing the EXE file to the folder in the external drive where you have copy-pasted the your game.
5. Click on "Apply" and "OK".
6. Now, try to start the game, and you should be able to play.
An alternate solution is given below.
In both the cases (internet game / purchased games):-
1. First plug in the external hard drive to your computer.
2. You will have to run the installation file of the game (both purchased and internet download) and select the folder path directing it to the external hard drive.
3. For some games, you may have to uninstall the existing game first to re-install and select the desire folder path (external drive).
4. Games will be installed in external drive and also available in start menu > programs > "your game".
Happy gaming! :)
May 13, 2010 | Computers & Internet
PS3 will play DVDs but not Games. Replaced the hard drive, restored the files, still did not work.
Then the Blu-Ray part of the laser pickup assembly is defect. Since DVD's use a different laser from the pickup, the DVDs will read fine. However the Blu-Ray part is defective and needs to be replaced.
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
My 360 only plays cds or dvd s wont play games please advise
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
Feb 15, 2010 | Microsoft Xbox 360 Console
Our playstation 3 won't read games but will play regular DVD's and CD's
I have the same problem. My games freeze after 5 minutes. Same with blue rays but dvds play fine. I have reformatted the hard drive and formatted the file system. Nothing has worked. Hearing through multiple sources the blue ray laser is going out or the latest firmware update could be causing this. Hard to know for sure ... major disappoint. I have the 80 gig. 2 years old just starting doing this three days ago. Any other suggestions?
Dec 26, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't load any ps3 games or play any blue ray dvd's it will let me play games i have stored on my hard drive and any other dvds could someone help????
blu ray len is burnt
needs to be replaced, if you have the bill and its under one year they will fix it for free.
if not it will cost you $150.00 US
http://www.ps3.com/
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
Playstation3, console plays games. when loading DVDs nothing happens
well you should change the hard drive to x5xxytr im only 10 yars old
Mar 17, 2009 | Sony PlayStation 3 40GB System
My ps3 wont play ps2 games or dvds
the only version of the ps3 that can play ps2 games and dvds is the one shipped from manufacter with 80gb hard drive
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
