Question about Kitchen Ranges
I've just bought a Kenmore Gas Range. It is working well EXCEPT that I can't seem to figure out how to set the TIMED BAKE feature. From the instructions it would seem that you should be able to set cooking time in hours and minutes by pressing up or down on the key pad; but when I do this it only sets the hours. There is a separate MINUTE TIMER function, and although the instructions don't spell it out, I'm wondering if this should be used in conjunction with the Timed Bake feature. Apologies if this question seems elementary, but some clear direction would be helpful, and an online Kenmore/Sears search hasn't produced anything helpful - so I'm turning to the FixYa gurus to solve my dilemma.
  • 1 more comment
  • bigwallytoo Aug 20, 2010
    Ginko: Thanks for your prompt response. Silly of me not to include the Model number with my question. In fact I did take a couple of pictures of the relevant parts of the Instruction Book, but then realized there isn't the capability to include pictures with questions on FixYa. The Kenmore range is a 30" free-standing model - No:7138. Cheers, Marianne
    Hi Ginko:
    Thanks so much for your explanation of what I need to do. Frankly, absent your clear instructions, I don't think I would have worked it out. Compared with my old "dinosaur" range, this digital application seems unnecessarily complicated.
    Anyhoo, rest assured if I ever get round to baking a halfway decent cake I'll be more than happy to share it with you, even if it's only via cyberspace.
    Thanks again, you are a star in my book.
    Very helpful indeed. As I explained to "ginko", I'm embarrassed to say that I would never have figured out the solution without his help.
    FixYa does it again!!
  • 19,396 Answers
Hi.
Can you please give us the model number of the range so that we can get a view of the control panel?
Controls are different depending on Kenmore model.
Thanks.
Ginko.
Posted on Aug 20, 2010
  • 1 more comment
  • Ginko
    Ginko Aug 20, 2010
    Re: Model 7138.
    thanks, it is a gas range, I'll be back to you in few minutes.
  • Ginko
    Ginko Aug 20, 2010
    Hi.
    On this oven what you cannot set directly is hours, like in other models they advance in minutes.
    First you may want to set the clock, that is simple.
    That is right as appears on instruction book, I quote:
    You activate and deactivate time of the day by holding down the pad pictured above for 15 seconds.
    To set timed baking:
    Press the timer Set/Off button, the light near to the button will come on.
    If you press button ARROW UP (not down arrow) quckly without holding, then the timer will advance in single minutes, if you hold it down, then it will advance in ten minutes block to allow you progressing by ten minutes in ten minutes.
    Note : the buttons do not allow you setting hours directly, you use the minute progression.
    If you press ARROW DOWN, the timer will start from hours 11.59 and progress down. better not using arrow down to program baking.
    Resuming. press Timer set, ensure timer is on, and press/hold minutes button until you reach desired time by advancing minutes (one by one or in group of ten if holding).
    After that press bake to set temperature.
    Send me a slice of cake when you have done :)
    Ginko.
  • Ginko
    Ginko Aug 20, 2010
    You are welcome.
    Have a great day.
I have a Kenmore gas range. The bake option doesn't work but everything else does. I've replaced the ignitor and still doesn't work. Any suggestions?
does the ignitor glow orange?if so could have a bad gas valve,clogged orifice,gas can't enter the tube.if it doesn't glow,bad clock assy.next time send the model number off of the machine
Nov 21, 2012 | Kitchen Ranges
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
Kenmore gas range, burners are working fine. Stove is not working, front panel, clock/timer..panel is off...
Hello there:
Please read the entire solution i have provided it doe4s cover things that you have said has already been checked but there is more to it
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician. The clock stopped The non-electronic clocks on gas range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Sep 28, 2010 | Kenmore 78733 Gas Kitchen Range
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Kenmore range oven will not hold temperature
You're glow bar ignitor is on its way out. I had this exact problem and swapped mine out with its identical sibling that runs the broiler element. Problem fixed.
Jun 22, 2008 | Tappan TGF320 Gas Kitchen Range
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Cannot figure out how to make oven work
Hi, try this and see if will help you. Most of the Gemini models are the same.
To set Bake:
1. Press the Bake pad.
• BAKE will flash.
• 000 will flash in the display.
2. Select the oven temperature. Press the
Autoset 0 pad for 350° F or the appropriate
number pads.
• Each additional press of the Autoset 0 pad will increase
the temperature by 25 degrees.
• The oven temperature can be set from 170° to 550°.
3. Press Bake pad again or wait four seconds.
• BAKE will stop flashing and light in the display.
Nov 20, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
