Question about Haier 65-Pint Dehumidifier
I have a Haier HD 456E dehumidifier and after 6 months of running the unit it stopped working. When I turn the switch to on, the display for the humidity went to either Hi or Lo and the unit would not turn on. I recieved another unit from Haier (a factory refurb unit) and in two months it was doing the same thing. I have two units now that they will not honor in warranty becasue they already replaced the frist on. Can anyone tell me what causes the Hi or Lo display and what the fix is for it. I thought it might be the humidistat board but I think it may be the main circuit board itself. So I may as well donate both units to the landfill. I wouldn't recommend buying anything from Haier if their quality is that bad. Any thoughts would be appreciated. Thanks
  • 105 Answers
SOURCE: Haier Dehumidifier HD50-T
A humidistat from a different brand will work, provided it is mounted well & hooked up properly. Make sure the replacement is designed to switch the compressor directly.
Posted on Jul 17, 2007
  • 625 Answers
SOURCE: Haier HDN655E unit runs but compressor won't kick in
use a jumper cord and go directly to the compressor to see if it will run. if it don't run, open up the motor box and see if there is a klixon overload inside. this should be normally closed. if it isn't replace it. the klixon is a thermal overload cutout. it usually trips because of high winding temperatures and protects the motor inside. the compressor is a hermetically sealed unit. no, or little freon will cause the motor to overheat.
Posted on Aug 21, 2007
  • 1902 Answers
SOURCE: Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: After 3 months, my Haier dehumidifier made a loud clicking sound
they are junk try to get a refund
Posted on Dec 11, 2009
  • 43501 Answers
SOURCE: Hello. I have a
Did a little search and the first part that came up for that model is the control board....that should tell you is the most commonly replaced part...
That is what is wrong with your unit...
The aprt is 100 bucks and is out of stock... but here's the url for the part...
Posted on Nov 29, 2010
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
Haier HD N655E
try plugging it into a known live outlet. if this still doesn't work, you need to get inside it. find the enthalpy control - humidity control and see if it turns. a contact inside may stay open preventing the fan and compressor from turning on. check your on-off switch if there is one. to remove the case look in back for hex head screws or on the bottom of the unit
Aug 27, 2007 | Haier AHD50 Dehumidifier
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
Jun 19, 2011 | Haier 45-Pint Dehumidifier
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
Jan 09, 2011 | Haier DE45EAL Dehumidifier
Water is not going into the tank, but it does run and panel lights up. Filter is clean. It worked for the past 2 months.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running.
If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils.
If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 16, 2010 | Haier HD656E Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
No lights or sound...changed outlets just stopped running, is there a fuse that could be blown?? or ???
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
Apr 13, 2010 | Haier HDN455 Dehumidifier
Amana D530M Dehumidifier won't run
We all appear to be in the same mess --Thanx Haier
This product says its Amana, but rest assured it is an Haier
The problem is most likely with the engineering design of the board. Im not an electrical engineer so be careful litning to me to closely :) There is only a half bridge rectifier on this board and 2 zener diodes that clamp down on the voltage. My guess on yours is the Zeners have been shorted and no longer clamping voltage down to aroun 24 volts for the low side of the board. I spoke with Haier and they have no schematics that state the zener specifications. They also said there was a 6 month backorder on ordering a new board. Oh and by the way if you want to order a new board and wait 6 months for the backorder it would cost you 75.00. All this jsut to repeat the problem again, because of bad design. O well ----- I wish products were not made better, so I wouldnt have to fill guilty about putting this in the landfills.
Nov 04, 2008 | Amana D530M Dehumidifier
Hampton Bay Dehumidifier Model# HB50
Jul 27, 2007 | Maytag M7DH45B2A Dehumidifier
Haier 65-Pint Dehumidifier Logo
200 people viewed this question
Top Haier Dehumidifiers Experts
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
