E-Machine want come on completely. You push power button. There is then a flash on the monitor. The Microsoft windows logo appears. A small box with 3 dots goes accross under the logo. This is the Copyright with Microsoft page. This stays for about a minute. Then you hear a click sound and the monitor turns black. Then everything keep repeat this and want completely come on!
  • 758 Answers
I would recommend that you try to start windows in safe mode and then try to do a system restore...Please clear here to get the instructions on how to start windows in safe mode...Or you can copy the the link on your web browser...
I hope this helps
Thank You
Posted on May 03, 2008
    Brigadier General:
  • 6,966 Answers
A number of possibilities:
1. the files needed to run Windows are either corrupt or missing;
2. driver error particularly with the video card;
3. virus infection;
4. hardware fault.
A temporary remedy is try to boot to Safe Mode by pressing F8 even before the Windows logo appears. On powerup, keep pressing F8 after the BIOS/CMOS display (POST).
Thereafter pls post back if Windows will boot in Safe Mode and we can work out other ways to restore Windows to normal operation.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 03, 2008
    Additionally, it may be to your advantage to make ready the following:
    i. Recovery CDs that came with the e-Machine; and/or
    ii. an OEM version of what Windows you are running.
FPD1930 gateway monitor powers up then a small box saying power save mode appears then it just goes black what's wrong with it
Hi. power save mode being displayed by the monitor could be caused by 3 things.
1)VGA cable to monitor is unplugged - check connections at computer and monitor
2)video card has been partially dislodged from motherboard socket. -remove computer cover and ensure video card is firmly pushed down into motherboard socket - do not use excessive force.
3)Monitor does not support video settings on the computer. - to fix on PC, turn on computer and press F8 button a few times during bootup - Windows will go to bootup screen - select SAFE MODE and hit enter. follow onscreen instructions - dont worry about weird colours and huge desktop icons - this is simply to get you going. Right click on desktop, select PROPERTIES>SETTINGS TAB. select screen resolution 1024*768 0r lower, select Apply or Ok. Now restart your machine
Dec 08, 2012 | Computers & Internet
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft:
and here:
and here:
on May 21, 2010 | Computers & Internet
Need instructions on a hard reset
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
Help me how to instal abode reader 10.0 1 im computer online
Installation instructions for Windows Internet Explorer
  1. Installation of Adobe Flash Player may require administrative access to your PC, which is normally provided by your IT department. It is recommended that you close all other open browser windows before continuing with the installation.
  2. Click the download link to automatically download and install Adobe Flash Player into Microsoft Internet Explorer.
  3. Depending on your security settings, you may see a Security Warning dialog box. Click Install to install the ActiveX control.
  4. When the installation is complete, you will see the Adobe Flash Player logo and text.
Installation instructions for Windows non-Internet Explorer
  1. Installation of Adobe Flash Player may require administrative access to your PC, which is normally provided by your IT department. For the installation to succeed, you may be asked to close all open browser windows during the installation.
  2. Click the download link. A dialog box will appear asking you where to save the Installer.
  3. Save the Installer to your desktop, and wait for it to download completely.
  4. An Installer icon will appear on your desktop. Double-click on it. You may be prompted to close open browser windows to continue with the installation.
  5. You can verify the version you have installed by visiting the About Flash Player page
kindly rate this solution
thanks and regards
Feb 14, 2011 | Computers & Internet
Pc has power but no response
Connect the video monitor to another working system to see if your monitor is the cause for your dilema.
If the computer logo appears when you first boot up, but it blanks out after the windows logo, then it would be an issue with your installation of windows and may be in need of a reload.
But again, if the monitor is completely black, I would test out the monitor on another machine.
Good Luck
Dec 20, 2009 | Sony VAIO PCV-RZ45G PC Desktop
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Aug 19, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
Vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
