REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
