Question about Sierra Wireless Aircard 860 PC Card (SIASIERRAWIRELESSAIRCARD860P)
Error 668 : connection was terminated !!! help me to solve this problem
3 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Sierra Wireless AT&T Aircard 668 Error
Run this wizard from Sierra Wireless to T/S the error:
http://www.sierrawireless.com/support/8x0wizard/welcome.aspx
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
Found the solution. There is a little tweak you need to make to the settings:It's posted here.
Updated link: http://quantumtom.com/2009/01/30/att-usbconnect-mercury-from-sierra-wireless-error-668-the-connection-was-terminated/
Posted on Jan 30, 2009
I have an mtd. Lawnflite model 135-668-352 and need a belt, but can't seem to find one. Can u help?
There are two belts in this parts list (and 6 other parts lists for your model) on this site:
Parts and Diagrams for MTD Lawnflite Mdl 668 352
May 20, 2014 | Garden
Check memory card - initialize - complete initialization -process terminated with error! Can You help me?
Just delete files off the sd card and you are good to go! Just solved this problem myself!
Oct 12, 2012 | Canon Legria HF200 Flash Media Camcorder
Dear Sir I am using Datacard of Airtell Model MMX 610 datacard. when I conntect the datacard, we can use the network for 5 minutes, after 5 minutes, connection is disconncting and giving error message...
Dear! Firstly uninstall the driver of your Data card and reinstall it, if it does not fix, kindly contact your service provider for this problem because I think it is due to network problem but firstly try the tip which I have suggested.
Jul 28, 2011 | Computers & Internet
How to solve u4 alarm in daikin inverter 24000btu unit
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Feb 08, 2011 | Heating & Cooling
Error 668 the coection was terminated
Usually associated with a 'choppy' or disconnected internet connection, for whatever reason - like the line outside your home, ISP problem - or incorrectly installed drivers /set upon your PC.
If the physical internet connection set up is fine on your PC ... cables- routers - - it can also be by driver problems. Try reinstalling the relevant drivers. It could also be a registry error.
Go first to http://download.cnet.com/Free-Window-Registry-Repair/3000-2086_4-10606555.html and download the free Windows registry repair tool. Run it when installed (takes about 5 mins to run).
If the connection still keeps dropping, try reinstalling any drivers you have - modem/router/wireless drivers etc
If the conneection continues to drop the problem may well lie outside of your hands - the ISP. It may just be a temporary problem.
Aug 14, 2010 | Acomdata PHOTON 2.5 (PHD080U2E54) Hard...
Can not conect to internet
call 410-668-2342 and i will help u right now
Jan 26, 2010 | Nintendo DSi Black Console
Have a sierra wireless 881 and keeps coming up error 668 tried with my cell sim and got same code whats wrong and how do i fix it with out att or spending more money
First of all you might want to check the firmware on the card to make sure it is up to date. There are two different versions of the 881, a usb model and a PCMI card. To get your firmware version by using your communication manager, go to tools>diagnositics>gsm info. Look on the device tab. The firmware version is near the bottom. Then go to www.sierrawireless.com/support and check that version against what they have there. If that does not work, set up a new connection profile. Here is a link showing you how to do so. http://www.mattsilverman.com/2008/08/error-668-sierra-881-wireless-aircard-att-3g.html
Sep 21, 2009 | Computers & Internet
Copier konica 7035 call service f-35-4
CAUSE: Incorrect AC wiring connections on the 4-pin fasten terminal block located in the rear of the fuser unit.
SOLUTION: Reconnect the AC wiring to the 4-pin fasten terminal block as follows:
While viewing the 4-pin fasten terminal block from the rear of the fuser:
RED wire from top lamp (L2), in the heat roller, is connected to the right front terminal.
BLACK wire from the bottom lamp (L3), in the heat roller, is connected to the left front terminal.
WHITE wire from the top rear position (closest to the web) of the main fuser connector CN13 is connected to the left rear terminal.
WHITE wire from the top front position of the main fuser connector CN13 is connected to the right rear terminal.
Feb 20, 2009 | Konica Minolta Office Equipment & Supplies
My air heater won't turn on it's a Dimplex DFB6016. What can I do?
call Dimplex : 1-800-668-6663 Ext: 358 These folks can solve your problem and send you replacement parts.
Dec 13, 2008 | Dimplex Compact Electric Flame Stove...
May 30, 2008 | Sierra Wireless Aircard 860 PC Card...
Computers & Internet Logo
470 people viewed this question
Top Sierra Wireless Computers & Internet Experts
Jerry Umali
ray gallant
Are you a Sierra Wireless Computer and Internet Expert? Answer questions, earn points and help others
