Question about Fuji FinePix F700 Digital Camera
Black screen with purple vertical streaks. Took it to Jessops said they wanted £127 to repair. enue screen ok.
  • graham_elain Aug 20, 2010
    Have checked all leads and plugs have also removed and refitted the LCD screen but the fault still there.
    Regards Graham
  • graham_elain Aug 21, 2010
    Thanks for the information, I tried what you suggested and it looks like the LCD panel is faulty.
    Regards Graham
  • 3,083 Answers
This sounds like a bad CCD- the part that detects the image and sends it to the LCD screen and memory, in which case the main circuit board would have to be replaced. If it was the LCD, you can get new or used ones on ebay, and try to fix it yourself, but, like I say, I'm not sure it will help, since the menu works, indicating a good LCD, at least from what I've seen.
In these cases, it's usually better to just get a new one on sale, since it can cost a lot to fix.
I saw that other people have had this problem on the net, but noone mentioned what was exactly causing it, but they were mentioning a lot of zoom problems, so it might be time to move on with a different product.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 21, 2010
  • 10,515 Answers
Play the Recorder Video / Image. Do you see the same Symptoms?
If yes, then you have Bad LCD Panel. You need to replace. The cost of repair might be high relevant to the Cost of the new one.
If the Recorder Video / Image is Fine, it is only a Problem when you are taking the Picture, in that Case, it is Faulty CCD sensor. This hit the Screen many years ago. There were Certain recalls and Extended Warranties. If this is the case, you need to Contact Manufacturer. If there is any recall, they would Repair it. Unless, you could try to Negotiate for the Repair price. I have seen many customer's getting a Goodwill gestures from these companies for Faulty CCD sensor.
For More, you could Read an Old Article :-
http://www.imaging-resource.com/badccds.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
    President:
  • 1,194 Answers
This problem can be due to bad CCD sensor unit or probably loose ribbon cable inside.
Open the camera and reseat all ribbon cables linked to the screen.
If the problem is still there then contact Fuji for bad CCD sensor.
Good luck and have a nice day.
Posted on Aug 20, 2010
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
We have a purple vertical line about half down the screen sometimes it works fine for a little while when we turn it on and about ahalf hour later it goes back to a purple streak
Was the TV manufactured in 2008? What is the model?
I have a failing LCD panel and am starting a class action lawasuit against Toshiba becuase there is a high number of failing units built during this time that Toshiba is not addressing and their customers are not being herd... well I am going to make them listen!
let me know if you want to be part of this activity.
andedwar@cisco.com
Dec 30, 2010 | Toshiba REGZA 52RV530U LCD TV
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
I have a thin purple streak on one side of my tv screen
panel is bad not economical to repair. usually repair is 90% of what you paid for tv new.
Jul 06, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Black screen on Kodak M753
You have a bad CCD imaging sensor. Not worth repairing. Very common problem with most point and shoot cameras. Suggest you buy a new camera.
Jul 02, 2009 | Kodak Easyshare M753 Digital Camera
I have purple streaks and black lines in the lcd of my caonon
That definitely sounds like impending CCD image sensor failure. As the camera is still under warranty (being only two months old), would suggest that you contact Canon at 1-800-OK-CANON to resolve this issue.
Jun 08, 2009 | Canon PowerShot SD1100 IS Digital Camera
Black vertical lines
ey there. have you solved this thing yet? you might want to check out this DIY plasma TV repair blog. there's a video on how to fix this.
Jan 23, 2008 | Samsung PPM42S3 42 in. Plasma Television
Fuji FinePix F700 Digital Camera Logo
54 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
