Question about Brookstone SmartSet Alarm Clock
No manual so my Brookstone CKS2022 goes off at different times and I don't know how to set.
  • daleygrace Aug 20, 2010
    i HAVE THE SAME problem did u find any answers?
I have a model AC101A, SKU#:568469 alarm clock, as I'm clueless in how to set it for my local time zone, etc
Contact them direct. The manual doesn't appear online
http://www.brookstone.com/customer-care.html
Nov 24, 2015 | Brookstone Audio Players & Recorders
Brookstone Model cks 2022 Alarm clock radio Instructions
I searched on your product name and found an instruction manual for a Brrostone self-setting alarm clock radio:
http://www.brookstone.com/webassets/pdf/607960p_manual.pdf
Apr 23, 2014 | Brookstone SmartSet Alarm Clock
Wireing guide for a brookstone stunt copter
If under Warranty (Brookstone or Extended) have them replace it. If not, suggest a Hobby Shop that specializes in R/C Helis
Apr 17, 2013 | Brookstone Stunt Copter RC Helicopter
Need instructions for model CKS2022
Emerson does not list a CKS2022 model. Other Smartset manuals are available here: http://www.emersonradio.com/owners/SmartSet%20Series/ . The instructions for a similar model like the CKS2021, http://www.emersonradio.com/owners/SmartSet%20Series/CKS2021_ib062603.pdf , or the CKS2023, http://www.emersonradio.com/owners/SmartSet%20Series/CKS2023_020504.pdf . may be the same as those for the 2022.
BTW: you can find the directions to update your Smartset for the modified Daylight Savings Time here: http://www.emersonradio.com/dst.htm .
I hope this helps.
Mar 06, 2011 | Emerson Smartset Clock Radio
How do you set the time on Brookstone iDesign Cube Clock Radio?
Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done!
Jul 05, 2010 | Brookstone (467522) Clock Radio
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
Unit shuts off after about 4 hours of running
You can get a manual on line. Go to www.brookstone.com , select "customer service", then select "product manual archives". It will come in a printable pdf file.
Dec 02, 2008 | Brookstone Pure-Ion (506840) Air Purifier
121 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
