Question about Mr Steam Mr. Steam Allegro Sauna Model A200 MST-A200
What does "prr" mean when displayed on the LED readout of the Mr. Steam control panel?
    Problem Solver:
  • 11 Answers
Hi my name is Mike I am with Mr. Steam Product Support. PRR is a code that shows up on our Steam Bath controls it was not used on our Sauna's. The PRR means there is a problem with the temp sensor on the control.please call me at 800-767-8326
Posted on Aug 23, 2010
Mr steam suddenly stopped steaming.
hi
the heater controller is not fully functioning when this occurs look into have the controller replaced at some stage
Dec 22, 2017 | Mr Steam Electrical Supplies
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Mr. Steam... 2.0. With a touch pad control pad. We bought a multicoloured light not in the bundled package and they said it would be controlled via the pad... However the electricians just connected...
Please make sure you have the MS Chroma light and not the CU light, as the CU light cannot be controlled by the controller. If you look in the instruction manual there is a section that indicates where the Chroma Light has to have two 24v request cables that run from the fixture itself and are connected to the pc board in the steam generator on two tab terminals labeled "chroma". Installing that will allow the controller to communicate to the Chroma light. Also double check with the electrician that has also ran a 120v power source to the light fixture itself and it is on a switch, left in the on position. If both these steps don't prove to be the issue you can remove the LED from the Chroma light and check the socket and verify you have 12v there. If there is voltage(chroma button pushed on the control pad first) and still no light then you may have a burned out LED.
Mar 20, 2015 | Mr Steam CULIGHT Commercial Steamroom...
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
Mr. Steam steamer is inppoerable
I just got this problem too, any solutions or a link to the manual?
Oct 06, 2009 | Mr Steam Mr. Steam Allegro Sauna Model...
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
LED display not working
Did somebody use the control lock by accident. Here is how to disable it. Hopefully it will work: The Control Lock feature shuts down the control panel pads to avoid unintended use of the oven. The Control Lock feature may be used either when the range is in use or turned off (for example, during cleaning). To lock/unlock control: Before locking, make sure the oven, the timer, and Timed Cooking are off. Press and hold the START pad for 5 seconds until ?CONTROL LOCK? appears on the display. Repeat to unlock, and ?CONTROL LOCK? will disappear from the display. Hope this helps Jason
Sep 04, 2007 | KitchenAid KESC308LSS Electric Kitchen...
Mr Steam Mr. Steam Allegro Sauna Model A200 MST-A200 Logo
497 people viewed this question
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
