Question about Kenwood KM800 Major Classic Stand Mixer
My detachable draft shaft burned by my stove where can i buy a other one
  • Kenwood Master
  • 3,740 Answers
I think your talking about the beater shaft. I can not relate to the draft shaft and I have been around a long time. This site has loads of KM800 parts in the UK. FYI Delonghi bought out Kenwood and getting parts in the US is through Delonghi. Their phone service takes forever!!!!
Try browsing this site:
http://www.4kenwood.co.uk/cgi-bin/catalogue.pl?pg=17&section=345619&path=345550,345619
There are 260 items for the Kenwood KM800 there
Thanks for choosing FixYa.
Kelly
p.s. Watch as your looking through the items. Many of them are no longer available.
Posted on Aug 20, 2010
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
The pin/groove that holds your paddle attachment fell out. How do I put it back in?
I would expect that to come as part of the shaft so don't expect to buy another one without the shaft. Factory pressed in supposed to never come out.
Sep 14, 2013 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
The rotating head on the mixer keeps falling off. how do you get it to stay on? it comes off when were mixing.
The Planetary plate comes attached to the shaft from the factory. It is not supposed to get
loose and come apart but it often does due to the mixer's vibrations and the user's constant
attaching and removals of the flat beater, wire whip or dough hook onto the beater shaft.
Try to remove the Planetary plate first : Gently rock it from side to side while pulling on it
to separate from the shaft. Notice the groves on both the shaft and inside the planetary
housing. That is how they are attached to one another at the factory (just friction, no screws
or pins). Now for a permanent solution:
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture on both the shaft (grooved section) and inside the
planetary housing. Now re-attach the planetary plate to the shaft. Use a long strip of duct tape
to hold the plate in place (to prevent it from falling back out). Allow the epoxy to dry overnight
or at least for 8 hours.
The Planetary assembly is now permanently attached to the shaft of the mixer.
Jun 10, 2011 | KitchenAid ProLine 600 Stand Mixer
Head of mixer is loose what do I do?
Feb 12, 2011 | KitchenAid KP2671 Professional 6 Series...
OLD hand held GE mixer needs new detachable beaters. OLD model number 30M47. Any suggestions where I might get them?
Hi. Truthfully, by the time you pay shipping you are money ahead to buy a new mixer. Go to Walmart where they have nice handheld ones in the 10 - 19 dollar range.
Jul 16, 2009 | Black & Decker MX55 PowerPro Hand Mixer
Sunbeam 275 watt 2366 mixer
it is probably the swich /pot combination on the electronic board. The shaft on the unit I have had twisted off and would no longer turn the switch on or off.
Feb 02, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Hobart p660
There are 2 set screws.Make sure their both out,if for some reason there is only 1 set screw these are your options.Heat the shaft and remaining pin with a mapp torch (you can buy them at home depot,lowes for $40 bucks),heat it up really good then get a punch and try to knock out the pin,option 2---if you cant get the pin out then youll have to replace the shaft and if thats the case you should also clean out the planetary and replace the bearings and seals.If the hole in the shaft is oblongated or worn you should probably replace the shaft because the dough hook will rock the pin back and forth breaking the pin.Also look inside the hook and make sure thatI its not worn out where the pin sets.IF you see thee hook or shaft pinhole worn you will break the pin again if you are able to replace the pin.I work for hobart and service mixers regulary,if you need part numbers or advise let me know.
Nov 27, 2007 | Hobart P660 Stand Mixer
Blades
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
Sep 21, 2007 | Bamix Mono Mixer
Kenwood KM800 Major Classic Stand Mixer Logo
352 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
